September 19, 2026, 02:18:20 am
Hoffman Amps Forum image Author Topic: Hoffman 6G15- Brown-face-style  (Read 9417 times)
Offline tdvt
« on: February 08, 2023, 05:31:24 pm »
I just powered up the newest project, gathered a few parts years back & that was as far as it got.
The traditional Fender layout for the 6G15 never appealed to me, so I decided to build it in a brown-face style to be paired with my Blonde Showman.
I used Doug's board, adapted to radial filter caps, & built it into a Brown-face Princeton chassis. I also changed the control order to something that made more sense to me.
As the chassis was pretty roomy, I was able to put all the transformers inside the chassis; an Antek toriodal PT, the little output transformer & the reverb driver.
A tip of the hat to Tubeswell for all his various posts regarding grounding schemes to help mitigate noise in these units. As a result, I built this one totally isolated from the chassis, with the only connection to power ground through a Merlin humblocker. It is absolutely silent into the Princeton Reverb test mule. (silent in a good way :)
Cabinet next..
« Last Edit: February 08, 2023, 05:33:26 pm by tdvt »
Offline bmccowan
  • Better builder than player
Re: Hoffman 6G15- Brown-face-style
« Reply #1 on: February 14, 2023, 07:32:58 pm »
I have an original brownface 6G15 and I built one with the idea of selling the original. But I am not thrilled with either of them. I'm interested in learning what you came up with following Tubeswell's guidance.
Mac
John Prine
Offline tdvt
« Reply #2 on: February 16, 2023, 08:06:59 am »
Well,
I distilled any number of things mentioned by Tubeswell (& others), into a ground plan & he was the one who specifically mentioned the Merlin Humblocker. (I had Valve Wizard article saved but didn't think to look there)
In the end. I built this completely isolated from the chassis except for the circuit ground to chassis through the hum-blocker.
  • In/out/foot-switch are completely isolated from the chassis mounting holes
  • Pot shells are at chassis ground potential but the pot circuit grounds run to a bus wire.  I have readily adopted Sluckey's flying bus wire technique for the controls & use it in everything.
  • Input to V1/P2 & .047/V2/P7 connected with shielded cable (as per Doug) + Dwell wiper to V1/P7 shielded cable.
  • Input jack-end of the bus wire, B+ ground & board ground all connect to the inboard-side of the hum-blocker, then the one ground to the chassis (same bolt as the toroidal shield)
End result is very quiet with no hum or noise into the guitar amp.
I would like to streamline the hum-blocker physical layout but used stuff on hand for this one (temp-ed in Orange Drop to be changed out) as it could be smaller. Merlin suggests using a 1-piece FWB for the diodes
PS  Noticed that the Merlin drawing shows 25A diodes, he states elsewhere a FWB of 3A-8A is adequate. Drawing not updated...?
« Last Edit: February 16, 2023, 08:10:27 am by tdvt »
