September 16, 2026, 07:27:00 pm
Hoffman Amps Forum image Author Topic: This confounded impedance selector!  (Read 5974 times)
Offline martinman
« on: February 12, 2023, 08:33:23 pm »
I just finished a 6v6 plexi build - my first build where I really took my time and assembled things.  I read through the schematic and tried to understand as much as I could.  When I powered up, I checked all the voltages at the major locations in at ABCDE on the board and all the tube pins via the schematics -- all spot on.  Nice!
I put a guitar cable in the input - put my finger over the other end, fire it up, and all I hear is a faint high pitch buzzing coming from the transformer OT when everything is dimed.  Nothing, not even a peep out of the speaker.
I'm going to dive in again tomorrow with a fresh set of eyes...  Been at this most of the day.
It's the standard classictone 18w OT
Orange, Green, Yellow to their respective taps.
Feedback from board to Green 8Ohm tap.
Switch output to output jack to tip
Black common from OT to output jack (Switch & Ground)
The only thing that I've modified is that I went with only 1 output jack.  I'm going to use the other hole for a NFB mod.
Any quick thoughts?
Offline martinman
Re: This confounded impedance selector!
« Reply #1 on: February 12, 2023, 09:03:16 pm »
Hrm… ok, it’s probably not the switch wiring…. Gotta be something  else.
I’ll double check the voltages and post tomorrow.
« Reply #2 on: February 13, 2023, 10:01:41 am »
I strongly suggest not to do that, as you may be putting the OT under enormous stress and risk wrecking it.
Offline acheld
« Reply #3 on: February 13, 2023, 10:33:54 am »
Any quick thoughts?
Yes, the first time I used an impedance selector I mis-wired it.
Not sayin' that you made this same mistake, but there is something about those switches that is counterintuitive . . . at least for me.
Pictures really help.
PDF is right, but you already knew that . . .
Offline martinman
« Reply #4 on: February 13, 2023, 11:30:14 am »
Here are some pics.  They're really difficult to capture, beacuase (like the dummy I am), i wired it before i actually installed it.  Live and learn.
Offline TenderTendon
  • Living in the past
« Reply #5 on: February 13, 2023, 12:10:48 pm »
You are using shorting jacks on the speaker output. NEVER do that. Ditch those jacks and use Switchcraft #11 instead.
Edit: I should have said "Don't use them, if you are going to have more than one output jack". Sorry about that!
« Last Edit: February 13, 2023, 12:37:24 pm by TenderTendon »
You mess with the bull, you get the horns...
Offline martinman
« Reply #6 on: February 13, 2023, 12:19:53 pm »
More pics of the build attached.
Voltages:
v1-DC  (Expected)(Actual)
1 - 127  133
3 - .77   .74
6 - 161  166
8 - 1.56 1.56
v2-DC
1 - 134   131
3 - .84    .89
6 - 238   240
8 - 135   132
V3 - DC
1 - 185   181
2-   21     21
3 - 33     34
6 -  170  177
8 - 33    34
A 402
B 401
C 278
D 240
E 225
Heaters are 3.3 VAC
All DC voltages seem to be in spec?
Online sluckey
« Reply #7 on: February 13, 2023, 12:27:59 pm »
I always use a #12A shorting jack for the main speaker jack, same as Fender. It's much safer for the OT to operate into a short circuit than it is an open circuit.
« Reply #8 on: February 13, 2023, 12:31:40 pm »
Understood, but he will definitely have problems when he wires that second jack and only plugs in one cable. Maybe he is already aware of that though. Would it be best to use a 12A for the main speaker jack and 11 for the extension speaker jack? I guess he could also just not wire up the shunt on the second jack. Sorry to confuse things...
« Last Edit: February 13, 2023, 12:38:43 pm by TenderTendon »
Offline martinman
« Reply #9 on: February 13, 2023, 01:03:02 pm »
Well...    Problem solved..   :BangHead: :cussing:
It's the speaker cabinet itself.  When I moved it one of the terminals to the speaker came loose.  I just.  Wow.
I read through RobRobinette's site and one of the first thing is either 1) guitar is not working or 2) speaker / cabinet is not working.
LOL.  I went right to the guts of the amp.
This was such a great project - I spent almost 6 months chipping away at it and finally finished it last night in a flurry of activity before the super bowl.  In my haste I skipped THE MOST basic test there is!
Lesson learned (again!).
To answer the questions about speaker jacks -- that's good info.  For now I'm just going to keep 1 speaker output.  With it now working, I'm going to enjoy it for a while and then look for NFB loop mods and use that second chassis hole for either a switch or pot.
Online sluckey
« Reply #10 on: February 13, 2023, 01:12:23 pm »
That's exactly what Fender did.
« Last Edit: February 13, 2023, 01:16:06 pm by sluckey »
