September 14, 2026, 10:10:21 am
Hoffman Amps Forum image Author Topic: Bridge rectified LED pilot, ground reference?  (Read 22060 times)
Offline slowferrari
« on: February 15, 2023, 12:47:49 pm »
I've got a spare 6.3V winding on my transformer, and I was going to bridge rectify it and use it to power a 12VDC led panel indicator (CLR is built in, and sufficiently low to work fine on ~9VDC).
The question is: does the circuit even need a ground reference or can I just leave it all floating? It's a fixed load and only drawing about .001 of the available current, so it doesn't seem like it should matter. Am I wrong?
Not drawing the schematic to avoid an unnecessary attachment, but we're talking about a full wave bridge rectifier with a smoothing cap and an led in parallel across the +/- dc terminals, so I assume we can all use our imagination.
Re: Bridge rectified LED pilot, ground reference?
« Reply #1 on: February 15, 2023, 01:07:38 pm »
Since you will be using a separate 6.3v winding you can ground it or not. Makes no difference to the LED. If this LED will be mounted near sensitive preamp level circuits I would provide a ground reference.
