September 08, 2026, 07:52:47 am
Hoffman Amps Forum image Author Topic: Pentode - triode switch power tubes  (Read 17845 times)
« on: March 02, 2023, 07:32:46 am »
Please pay attention to the pin numbers on the power tubes and double check for errors prior to wiring your amp with a pentode - triode switch.  Make sure you are using a proper DPDT switch for this application.
The screen and plate numbers are often different for different power tubes.
CHECK for ERRORS!
