September 16, 2026, 08:12:58 am
Hoffman Amps Forum image Author Topic: output transfo kaputt  (Read 8521 times)
Offline Tirol29
« on: March 08, 2023, 07:54:36 am »
Hello,
while playing at max volume on my diy amp (cf:  https://el34world.com/Forum/index.php?topic=25354)
suddenly there was a big noise . i stop everything when i retry no sound at all.
After look out on the bench,  it occurs that the output transformer, a classictone 40-18031, was sparkling, i dismounted it and found burn wires
do you know what could be the cause ?
i am ont the way to buy a hammond 1750B i think that's correct.
Re: output transfo kaputt
« Reply #1 on: March 08, 2023, 08:04:20 am »
EXCESS current at the other end of those wires most likely the cause
so the PA tubes bias, the tubes themselves, and surrounding parts in the PA
Offline Tirol29
« Reply #2 on: March 08, 2023, 08:13:29 am »
tks shooter,
i have another 6v6GT (old mazda Belvu) i will put in place when i will have wired the new transfo, in case it was the cause (which is the most likely)
« Reply #3 on: March 08, 2023, 09:03:48 am »
This is most likely the cause.
Offline Tirol29
« Reply #4 on: March 08, 2023, 11:27:00 am »
and maybe another related cause : friday evening and big muff  :angel
Offline dude
« Reply #5 on: March 08, 2023, 12:16:32 pm »
What's Big Muff.. :icon_biggrin:
Offline bmccowan
  • Better builder than player
« Reply #6 on: March 08, 2023, 04:17:05 pm »
What's Big Muff?
BYOC has a diy version named Large Beaver.
https://buildyourownclone.myshopify.com/products/large-beaver-rams-kit
Mac
John Prine
« Reply #7 on: March 08, 2023, 04:22:57 pm »
since you said "I have another 6V6GT..."  is this a PP or SE amp?  Got a schematic?  might help so you don't repeat.
my builds like the Big Muff and everyone on 10, but I take that in consideration when I by Iron, how I bias the amp, and what size ah-sheet fuse to use
Offline scstill
  • https://stillampd.com
    • Still Amp'd
« Reply #8 on: March 08, 2023, 05:28:12 pm »
What's interesting is that in reply #10 of your earlier post on this amp (btw this link shows SE with schematics), the 8k red lead looks to be connected to the terminal strip without a corresponding connection, yet that is the wire that seems most fried. Seems that somehow high current flowed through red. When I have unused transformer leads I will just heat shrink  the ends and tuck away in the chassis.
« Last Edit: March 08, 2023, 08:02:54 pm by scstill »
« Reply #9 on: March 08, 2023, 10:52:20 pm »
The power tube shorted. Happened on a VT-40. Smoked the irreplaceable OT and stunk-up the room.
So replace your power tube before you burn your new OT.
Offline Tirol29
« Reply #10 on: March 09, 2023, 02:38:53 am »
at that time of picture it was not yet 100% completed. Since then unused wires have been soldered to free terminal tags before first power on  :smiley:
« Last Edit: March 09, 2023, 02:47:48 am by Tirol29 »
Offline Tirol29
« Reply #11 on: March 09, 2023, 02:46:29 am »
thanks PRR,
that's what i said in answer #2. For the actual and suspicious tube i'll contact on OM who has several tube testers. At first sight i don't see any trace of overheating but that  means poor i guess.
Do you agree with Hammond 1750B choice ?
« Reply #12 on: March 09, 2023, 08:11:21 am »
Uncle Doug used a 15w classic tone OT   the1750B is 10w.  A Hammond 125ESE is 15w with lots of hookup options.
If you are only using a 6V6 then the 1750B would work and it's half the price of a 125ESE.
Offline 66Strat
« Reply #13 on: March 09, 2023, 09:46:24 am »
Hello,
My bet would be square wave induced fly-back voltage spikes. You may want to consider implementing fly-back voltage protection diodes.
Regards,
JT
« Reply #14 on: March 09, 2023, 01:30:25 pm »
Sorry.
....i don't see any trace of overheating but that  means poor i guess.
Last year the muffler fell off my car. I think the same thing sometimes happens in vacuum tubes: parts come loose. Except the other electrodes and the glass bottle keep them from falling out on the road.
Offline Tirol29
« Reply #15 on: March 09, 2023, 05:16:45 pm »
Sorry.
no no you don't have to ! i didn't express any frustation or what so ever.   :dontknow:
« Reply #16 on: March 09, 2023, 08:40:06 pm »
_I_ get frustrated when people do not read the thread.
I am sorry to be guilty of this myself. I will give myself 12 lashes with a stale cheesecake. (Long story........)
« Last Edit: March 09, 2023, 08:44:39 pm by PRR »
« Reply #17 on: March 10, 2023, 05:43:41 pm »
oh   stale cheesecake   ummm     what a waste
How To Tell If Cheesecake Is Bad? - Cully's Kitchen
« Last Edit: March 10, 2023, 05:49:09 pm by mresistor »
Offline Tirol29
« Reply #18 on: March 14, 2023, 12:49:08 pm »
hi,
received and replaced OT with 1750B : all fine  :smiley:
Boys are back in town :m8
another success for the working class   :bravo1:
