September 16, 2026, 09:28:36 am
Hoffman Amps Forum image Author Topic: 1970 Super Reverb: Low Plate Voltage and Very Low Plate Current  (Read 5830 times)
Offline Pinball
Working on a 1970 Super Reverb. New JJ 6L6GC's and a NOS RCA 5U4.
Incoming Voltage is 117 VAC
Plate Voltage is 414 VDC
Plate Current is 9mA
Both 6L6 tubes are very similar.
I can turn the Bias adjustment POT and never get close to 50% of tube max before running out of adjustment.
Also Tried a JJ New GZ34 and didn't get much better.
Any help would be appreciated.
Re: 1970 Super Reverb: Low Plate Voltage and Very Low Plate Current
« Reply #1 on: March 09, 2023, 04:24:50 pm »
What's the control grid voltage? What's the screen voltage? Screen resistors OK?
« Reply #2 on: March 09, 2023, 05:09:12 pm »
Also, did you replace all the filter caps including the bias supply filter caps?
Offline Pinball
« Reply #3 on: March 10, 2023, 09:52:59 am »
Control grid voltage is -49.3
Screen grid voltage is 427
Screen resistor is .495k
Control grid resistor is 1.528k
I have replaced all electrolytic capacitors.
« Reply #4 on: March 10, 2023, 11:07:01 am »
Where are you measuring this? At the socket pins?
Offline Pinball
« Reply #5 on: March 10, 2023, 11:41:39 am »
socket pins
I have -44.8 between the two 10k coming off the Bias pot. BTW the bias pot only shows 6.75k total across the two outer leads.
« Reply #6 on: March 10, 2023, 12:15:02 pm »
So you need to be hotter, so decrease the bias pot tail resistor. (Try tacking various parallel resistors in). -49V is too high for 414V. You want to be around 10% of plate voltage +/- 2%
Offline Pinball
« Reply #7 on: March 11, 2023, 05:45:47 pm »
That was it. Thanks for your help on this. Dropped that resistor down to around 9-10k.
