September 16, 2026, 11:38:18 pm
Hoffman Amps Forum image Author Topic: Tech help request - Which math to determine neg voltage & Rk value on Mixed Bias  (Read 5072 times)
This days I spent some time to find documentation about the use of Mixed Bias on Tube Amps (Fixed Bias + Cathode Bias)
Now I'm asking help for the math to use
As I'm not very comfortable with calculations usually to choice a Fixed Bias Voltage or the value of a Cathode Resistor I look to similar plans and plagiarize or, at least, I use an online Bias calculator
This time I must do an effort and learn some math
I would like to learn which are the calculations envolved to establish the negative Fixed Bias voltage and the value of the RK resistor if I want to realize say ... 35% of fixed Bias and 65% cathode bias, 35% and 65% are an example, may be I would like to use different percentages of each different Bias
Values that I have to use are the 12W of dissipation of the el84 tubes, I'll use a pair, so total 24W max plate dissipation, 330v B+ (may be anode cathode voltage around 315/325v, may be) and a load of 8Ka-a
Many Thanks
Online sluckey
You seem to be sharply focused on mixed bias these days. Why?
This is what I would try. I'll use my AC-15 amp as an example since the voltages are pretty close to your numbers. I have decided that 12V will be my magic bias number. Remember, bias voltage is the difference between grid and cathode voltages. So, I want 35% of that 12 volts to be a negative voltage placed on the grid. 35% of 12 is 4.2V. I adjust my negative bias supply to put -4.2V on the grid. That leaves 7.8V to be put on the cathode. So, I experimentally determine the value of cathode resistor that will put 7.8V on the cathode. The combined effect will give a total bias voltage of 12V, which is what I wanted.
This may not be the exact answer you seek and my example may be overly simplistic, but this is what I would try. I don't know if it's even possible to completely solve your problem in the classroom. Sometimes you must also go to the lab to get the total answer you seek.
Ciao Steve, Grazie
Yes, this days I'm trying to understand better what is around Mixed Bias
The reason ? The purpose is, as I'm drawing a conversion plan for a Geloso G1 1020 A for a guy, to use the existing Fixed Bias and to experiment with something new to me and at DIYItalia
Your suggestion usually will be my approach, but as I haven't the amp under hands (it is of a guy that lives far from me) I'm trying to give him the more support I can (he isn't so skilled) and if along the way I learn something new is all gained for me
Use a plate characteristics chart to plot a load line and bias point (to calculate total cathode current) and determine the bias voltage split (35% grid 65% cathode or whatever) and (having calculated the cathode current already) use ohms law on the cathode voltage to get the cathode resistor value you need.
Ciao Tubeswell
Plot a load line ...  :help:
OK let's start further  :sad2:
Say I know that the current that must flow on cathodes must be 60mA (330v B+ - 2 x EL84 Tubes - 8Ka-a load)
Cathode Bias = 65% of 60mA = 39mA
Fixed Bias = 35% of 60mA = 21mA
To obtain 7.8v on the Cathode Resistor @ 39mA flow the resistor value must be 200R
And to have the other 21mA flowing on the catodes, to obtain the 60mA, as Steve say -4.2v must be supplied to G1
 :dontknow: :dontknow: :dontknow:
Total Crazy  :w2: :w2: :w2:  or Correct  :w2: :w2: :w2:
I really don't know
« Last Edit: March 17, 2023, 04:08:56 pm by kagliostro »
Keep it simple.
Say that a 13QU6 typically wants 234 ohms self-bias or -13V fix-bias.
Try 117 ohms with -6.5V for 50:50 mix-bias.
You want mostly self-bias? Try 0.65*234r with 0.35*13V.
Pre-compute a safe cathode current for the B+ voltage you expect. Have a 1-Ohm series resistor and a DVM connected for smoke-check and be ready to shut-down fast if current goes too high.
« Last Edit: March 17, 2023, 06:41:48 pm by PRR »
Ciao PRR Many Thanks
So, if I understand you correctly
I start from the specifications of the el84 and check, for the same voltages, the required negative voltages and the RK value
in AB1 PP using 300v B+ and a load of 8Ka-a application data are
Fixed Bias =  -14.7v
Cathode Bias = 130R
to set Fixed 50% + Cathode 50% is -14.7v / 2 = -7.35v and 130R / 2 = 65R
if I want Fixed 35% + Cathode 65% is 0.35*-14.7v =  -5,145v and0.65*130R = 84.5R
This seems a simpler way to consider things
my only incognita is about the fact B+ isn't 300v, it is 330v
But proceeding with caution there shouldn't be any problems getting to a correct setting
Thanks Again
 :think1: :think1: :think1:
Here is late and so strange thoughts cross my mind
a voltage of -10v bias hotter than a voltage of -15v
a 100R resistor bias hotter than a 150R resistor
if this is correct I am in confusion ....
did you see what I see or am I completely lost ???
« Last Edit: March 17, 2023, 08:58:55 pm by kagliostro »
