September 16, 2026, 10:23:39 pm
Hoffman Amps Forum image Author Topic: Hammond AO-29 Field Coil PT question  (Read 4648 times)
Offline tdvt
« on: March 23, 2023, 10:50:19 am »
Hoping to use up a salvage AO-29 PT (field-coil version) in an amp project for a friend, what would essentially be a single-channel Deluxe Reverb w/no trem. I would like to use a tube rectifier & land at around 420V B+.
From reading about these PT's in other threads, I had mentally filed away that a 700Ω power resistor in series on the center tap, taking the place of the field-coil, would bring the voltage down into usable range.
Having just rebuilt the PS section of an ultralinear Pro Reverb that uses a two power-resistor voltage divider to drop voltage for B+ node "B",  I am wondering if that is a more viable method to deal with the high PT voltage instead of the CT resistor.?
Or even a combination of the two methods?
Re: Hammond AO-29 Field Coil PT question
« Reply #1 on: March 23, 2023, 12:45:01 pm »
The single resistor in the CT looks good to me. In, addition, it will provide a free source of negative voltage for your bias circuit.
Offline tdvt
« Reply #2 on: March 23, 2023, 01:20:56 pm »
Thanks for checking that out & good point about the bias supply.
