September 16, 2026, 05:22:22 am
Hoffman Amps Forum image Author Topic: AC15 weird electric noise  (Read 8341 times)
Offline Travis8
« on: March 27, 2023, 10:54:12 am »
Hi,
My vox ac15 make a weird noise without tubes and If i insert the tubes the noise come bigger.
Also the signal of the guitar doesnt sound and I check the basic, all look fine... some ideas?
Thanks you all
https://drive.google.com/file/d/1Z34eSeIxhBKVUNcRixGKHs7o5MULbwET/view?usp=sharing
Re: AC15 weird electric noise
« Reply #1 on: March 27, 2023, 12:45:51 pm »
It is a solid 100Hz buzz. I assume you are not in North America?
If this is self-built, it looks like an oversight in wiring the power supply.
Offline Travis8
« Reply #2 on: March 27, 2023, 01:21:43 pm »
Itīs a AC15C1 Iīm in europe.
Offline Travis8
« Reply #3 on: March 28, 2023, 01:50:35 am »
I will check 5W resistors today, yesterday I check with tubes and without it, and the noise still there.
Itīs weird..
Offline Travis8
« Reply #4 on: April 11, 2023, 05:00:06 am »
I try to replace 5W resistor and the noise still there.
When I pull out tubes the noise come down but when I put the power tubes the noise comes up very high.
Some ideas?
Offline Travis8
« Reply #5 on: April 11, 2023, 05:12:39 am »
How can I check if power supply caps are ok?
thanks
« Reply #6 on: April 11, 2023, 08:32:27 am »
Filter cap(s)
Offline Travis8
« Reply #7 on: April 11, 2023, 09:00:32 am »
Filter cap(s)
Yes I will try to changue it, some way to test it before?
Thanks..
« Reply #8 on: April 11, 2023, 02:03:49 pm »
Filter cap(s)
Thanks..
If you solder-tack a suitably rated electrolytic cap in parallel with the suspect cap (observing the same polarity) and the noise goes away, there it will be.
Offline Travis8
« Reply #9 on: May 03, 2023, 05:51:50 am »
