September 18, 2026, 11:54:30 am
Hoffman Amps Forum image Author Topic: Using 6g16 Chassis for Building anAB763 Vibroverb Amp  (Read 6836 times)
Offline bobspart69
« on: March 31, 2023, 02:31:05 pm »
Ok, Can this been done with limited modification and no extreme crowding? Due to a lack of parts for an AB763 Black Face  VibroVerb amp I'd like to install in a brown face chassis . I don't want the amp to look like a Rube Goldberg contraption. Can I maintain a reasonably tidy chassis with minimal modification ?Know there will be size differences in the PT and OT and I'm guessing the preamp board. Don't need the ON/ OFF switches for the channels. Or does anyone know where I might pick up an AB763 Vibroverb chassis  and faceplate (preferably no logo on the front) Any input is welcome.
Thanks all,
Robert
Re: Using 6g16 Chassis for Building anAB763 Vibroverb Amp
« Reply #1 on: March 31, 2023, 02:55:14 pm »
I think you could do it tidy in a 6G16 chassis, but that’s up to you.
Offline bmccowan
  • Better builder than player
« Reply #2 on: March 31, 2023, 03:06:15 pm »
I was curious as to what your concern might be and snooped around. It seems the black chassis is only about 1/4" longer. Same tubes, same pots and jacks. Black PT slightly bigger. Seems like a piece of cake. I know there are blackface faceplates out there, but I do not know if they fit the brown chassis. I
Mac
John Prine
Offline bobspart69
« Reply #3 on: March 31, 2023, 04:14:43 pm »
Believe the AB763 is bout 1/2" longer but and inch wider, deeper if you will, and there's the concern. If all can be fitted in properly a black face plate isn't necessary. Tough to find the faceplate and chassis. Brown is dandy.
« Reply #4 on: March 31, 2023, 04:40:45 pm »
Yes here is what you want.. however he wasn't taking PayPal last time I checked  his chassis are as close as you can come to the real deal.  It has logo on the front though.
http://www.solandfa.com/products-Vibroverb-Reverb-Chassis-Kit.asp
« Last Edit: March 31, 2023, 04:42:56 pm by mresistor »
Offline bobspart69
« Reply #5 on: March 31, 2023, 05:09:14 pm »
  Correct about PayPal and last I checked none in stock. I could contact again. Marsh I believe has chassis but no faceplate. Want to make sure I can get both before ordering. Therefore the question of the switch to a 6g16 chassis. Mojotone has those.
Offline bmccowan
« Reply #6 on: March 31, 2023, 06:25:52 pm »
As far as physically fitting the parts - the one difference I see, besides a different PT, are the two bright switches. Those are the switches you said you could drop? The chassis depth should be no problem, plenty of breathing room.
And my totally silly decision would be that I like the looks of the brownface better, so I'd go that way. I have built a brownface Princeton and Deluxe; and rebuilt a brownface Concert. I love the way they look and sound. And I am so tempted to build either a Brownface Super or Vibroverb. :icon_biggrin: If I do that, I'll sell the Concert cause its so heavy I can barely move it.
Mac
John Prine
« Reply #7 on: March 31, 2023, 06:41:13 pm »
Should you find that you miss the bright switches, just use a volume control with a push/pull SPST switch.
Offline bobspart69
« Reply #8 on: April 01, 2023, 08:08:31 am »
SPST volume switch. That's clever. Would have never thought.
Offline bobspart69
« Reply #9 on: April 01, 2023, 03:58:58 pm »
OK everyone. Hammond Electronics is showing both the AB763 (125p5d) and the 6g16 (125p6a) as being replaced by their 290dex transformer. Hate to do this but I'll ASSUME there may be no mods necessary. But it lists the voltage to rectifier at 325V and Fender lists it at 460V. I suspect I'll contact Hawk Electronics who sells them and see what they have to say. Maybe get the mounting stud distances then see if Mojotone can confirm those distances with their chassis.
Thanks all, have the best.
Robert
Offline bmccowan
« Reply #10 on: April 01, 2023, 06:35:58 pm »
I think you may be mixing apples and oranges; AC voltage to the rectifier and DC voltage from the rectifier.
Take a close look at the two schematics.
Mac
John Prine
Offline Bieworm
  • I like it loud!
« Reply #11 on: April 03, 2023, 06:49:54 am »
Why not a deluxe reverb chassis and faceplate? Plenty of generic stuff on that one around. I even fitted a tone king imperial clone in one of those.. relays and all
I exclusively use blackface Bassman chassis for bigger amps. They are less wide, but an inch deeper… very nice size. But I make my own faceplates
« Last Edit: April 03, 2023, 06:53:51 am by Bieworm »
Offline bmccowan
« Reply #12 on: April 03, 2023, 10:36:36 am »
Hey Bobspart,
I fired up my memory banks and remembered maybe obtaining a Blackface Vibroverb Chassis. So I went to my future projects shelves and there it was - still in its box. Its really nice. has both aluminum faceplates still with their protective plastic covers, eyelet boards, and a full length brass grounding plate.
I searched and found the vendor: http://www.solandfa.com/about_us.asp He had/has a good reputation.
Since I would rather build a brownface, and you want a blackface, maybe we can swing a deal. I'm happy to let it go to you for the price of a similar brownface chassis & plates. An even swap.
If interested send me a PM and we can work it out.
Mac
John Prine
