September 17, 2026, 03:52:27 pm
Hoffman Amps Forum image Author Topic: Omit Presence knob, but keep it in the circuit?  (Read 6096 times)
Offline passaloutre
« on: April 06, 2023, 02:23:20 pm »
I have an amp which is essentially a Bassman preamp, Blackface reverb circuit, and Tweed Deluxe-ish power amp (schematic attached).
I pretty much leave the Presence control at halfway all the time and never change it. I'd also like to add a Master Volume. My thought it to fix and internalize the "Presence" control and put the MV pot in its place.
Now the Presence control, being a pot and a capacitor, could be replaced with two resistors and a capacitor obviously. But I'm trying to save some board space, since my layout never counted on putting three more components in there, and I'm maybe a little anal about piling up components where they weren't supposed to be (I like a neat board).
Anyways, would it be possible to replace that 5k pot and 100n cap with a single resistor and capacitor? Like, would a 5k resistor with a parallel 47n cap be equivalent to the pot turned halfway up? I hope this is making sense.
I know I could just drill another hole for another knob, or even put it on the back, but I never move the Presence knob, so I'd like to eliminate it if possible.
Re: Omit Presence knob, but keep it in the circuit?
« Reply #1 on: April 06, 2023, 02:46:09 pm »
Experiment. Replace the pot with a 4.7K or 5.1K resistor. Replace the .1 cap with different values until your ears are happy.
Offline passaloutre
« Reply #2 on: April 06, 2023, 02:52:49 pm »
You mean I actually have to listen to the thing?  :l2:
« Reply #3 on: April 06, 2023, 03:17:26 pm »
Only if it’s replacing a 10k linear pot (I’m assuming you’re meaning a 5k/5k voltage divider)
« Last Edit: April 06, 2023, 03:19:33 pm by tubeswell »
Offline passaloutre
« Reply #4 on: April 06, 2023, 03:26:11 pm »
The existing Presence pot is 5k, and it's set halfway, so the divider is 2k5/2k5.
« Reply #5 on: April 06, 2023, 03:32:25 pm »
You could use the same method as before...
« Reply #6 on: April 06, 2023, 06:31:23 pm »
Now you’re getting there :-)
Offline jeff
  • Need input
« Reply #7 on: April 07, 2023, 11:46:13 pm »
Edit: Post a picture of your board/layout
« Last Edit: April 08, 2023, 12:18:35 am by jeff »
Offline jeff
  • Need input
« Reply #8 on: April 07, 2023, 11:46:35 pm »
I don't want to give bad advice if your board is laid out differently
« Last Edit: April 08, 2023, 12:19:59 am by jeff »
