September 17, 2026, 08:24:54 pm
Hoffman Amps Forum image Author Topic: Unused 100V, 230V, 240V taps  (Read 4832 times)
Offline jeff
  • Need input
« on: April 09, 2023, 09:44:55 am »
What advice could you give for dealing with a transformer's unused 100V, 230V, and 240V taps?
Shrink tube flush cut ends leaving extra length, fold extra length over, shrink tube again, zip-tie some place safe?
Solder to a tree/standoff?
Thank you.
Offline dude
Re: Unused 100V, 230V, 240V taps
« Reply #1 on: April 09, 2023, 09:53:46 am »
I think you answered your own question... :icon_biggrin: Happy Easter!
Offline jeff
  • Need input
« Reply #2 on: April 09, 2023, 10:17:07 am »
Cool, thanks
Always helps to have a 2nd opinion, case I'm overlooking something. Wasn't 100% sure.
🎶"...and every time I think I know just what I'm doing
That's when my troubles exceed"🎶
Happy Easter to you too
Offline acheld
« Reply #3 on: April 09, 2023, 02:49:25 pm »
Solder to a tree or standoff?   No, don't do that.
Flush cut, yes.   Heat shrink -- use the good stuff, eg double walled with glue inside.  I have seen the non-glue versions fall off.
Offline jeff
  • Need input
« Reply #4 on: April 10, 2023, 07:03:24 am »
Ah, thanks!
This is why I ask, never knew bout the glue!
« Reply #5 on: April 10, 2023, 11:59:29 pm »
Tie them to a barrier strip, makes line volt changes a lot easier - Just a screwdriver.  Assuming of course, that you have enough chassis space for one. On other builds I have located the barrier strip on the inside wall as well.
--Pete
