September 18, 2026, 01:08:32 am
Hoffman Amps Forum image Author Topic: Presence control causing high pitch oscillation question  (Read 4857 times)
Offline jackplug1
« on: April 12, 2023, 12:03:06 pm »
The presence control causes high pitch oscillation at low settings in my Seplex build.
It disappears at higher settings so long as the MV is not too high
I does not appear to be affected anything before v2b
I have researched this but this fault seems to relate to push pull amplifiers and is to
do with postive feedback and reversing the opt secondary leads.
The NFB wire is screened and I have moved the presence control wires away from the
tone stack
The fault is not present if the NFB wire is disconnected.
Also the presence control has no effect on the tone
Should I replace the nfb resistor with a different value ?
BTW I am using a 6v6gt with the appropriate cathode components
There is no mention of this problem here:
https://chasingtone.com/the-seplex/
« Last Edit: April 12, 2023, 12:09:38 pm by jackplug1 »
Re: Presence control causing high pitch oscillation question
« Reply #1 on: April 12, 2023, 12:17:48 pm »
Have you tried flipping the polarity of either the primary or secondary OT windings?
Maybe presence will work after that. If not, please provide well lit, in focus photos of your build.
« Reply #2 on: April 12, 2023, 12:25:13 pm »
Swap the two OT primary wires.
« Reply #3 on: April 12, 2023, 06:37:02 pm »
"at low settings", the Presence is doing nothing.
Let's check. Disconnect it.
I am thinking the power amp is just unstable, but moderated by turning-down the Master. Showing that the Presence is just a side-track.
And what they said. Pictures! And swap leads.
Offline jackplug1
« Reply #4 on: April 13, 2023, 07:35:09 am »
I tried swopping the secondary wires before but that made no difference so I put them back to what they were.
Following the advice I reversed the primary ones and the fault disappeared, so thank you!
I think I have noticed that the amplifier sounds a lot more healthier, or is that my imagination?
I don't know what the explanation is for the fault which was corrected though.
