September 17, 2026, 10:40:38 pm
Hoffman Amps Forum image Author Topic: LBL on Variac ?  (Read 5882 times)
LBL on Variac ?
« on: April 13, 2023, 02:30:01 pm »
Can variac be run safely on a light bulb limiter?
Online sluckey
Re: LBL on Variac ?
« Reply #1 on: April 13, 2023, 04:37:06 pm »
Sure. But I can't think of a single good reason to do so. What's your objective?
Re: LBL on Variac ?
« Reply #2 on: April 14, 2023, 08:22:39 am »
I should have been more specific.  I was wanting to use it at the input to the variac. Guess it would work there too.   Thanks.
Re: LBL on Variac ?
« Reply #3 on: April 14, 2023, 09:19:43 am »
I suggest
Mains -> variac -> LBL -> load
Re: LBL on Variac ?
« Reply #4 on: April 14, 2023, 09:33:34 am »
I think he was planning to use the LBL before the Variac because the lamp is chosen in reference to a specific voltage and wattage and resistance is strictly joined to it in a lamp
But May be it will act correctly also if connected after the Variac
« Last Edit: April 14, 2023, 03:41:16 pm by kagliostro »
Offline acheld
Re: LBL on Variac ?
« Reply #5 on: April 14, 2023, 10:56:34 am »
Or, maybe he is worried about his Variac!
Re: LBL on Variac ?
« Reply #6 on: April 14, 2023, 11:11:29 am »
Ok, I was under the impression that a variac would draw a high initial current surge, then a fair bit of magnetising current.
I thought that might keep a lower wattage bulb bright.
On checking mine, the initial surge current is high, but the magnetising current seems to be negligible.
I think either way around would be ok.
Re: LBL on Variac ?
« Reply #7 on: April 14, 2023, 11:21:17 am »
Well I actuall tried it and it wasn't creating any harm.  But as pdf64 stated using the LBL between the load and the variac is a better method.
« Last Edit: April 14, 2023, 11:25:56 am by mresistor »
