September 17, 2026, 10:53:00 am
Hoffman Amps Forum image Author Topic: Runnin 120VAC leads near the preamp section?  (Read 5439 times)
Offline joesatch
  • save me from myself.
« on: April 16, 2023, 11:29:34 am »
Space issue on the chassis. I need to install a 14vAC PT for DC heaters above the preamp section outside chassis. (2204 style). The AC leads for the PT will be running along the inside chassis to the other side where the mains are(the AC  leads  will be running under the pots against the edge of the chassis). What issues will i encounter?
Re: Runnin 120VAC leads near the preamp section?
« Reply #1 on: April 16, 2023, 12:07:39 pm »
What is the need for this? Why not just install a 6.3VAC filament PT?
« Reply #2 on: April 16, 2023, 12:34:02 pm »
Whatever the secondary......He still wants to run 120VAC right near the preamps.
Seems a bad idea to me.
Offline joesatch
« Reply #3 on: April 16, 2023, 12:34:55 pm »
because i'm powering 3 12ax7 plus a couple relays
