September 18, 2026, 05:26:00 pm
Hoffman Amps Forum image Author Topic: Princeton tonestack bypass wiring question  (Read 6578 times)
Offline jordan86
« on: April 24, 2023, 04:56:38 pm »
Hey guys!
I still love my Princeton Reverb that I built back in 2020, which so many of you helped me on. I did add eventually a "RAW" control on the back of the chassis - in the "ground switch" hole.  It's just a 500K pot that sits in series between the fixed 6.8K mid resistor and ground. As I crank it up, things get more "tweedy". Rough schematic attached. I like the varying levels of midrange on the raw pot but I'd love to add a complete bypass of the tonestack. You know, for when you just need a little "extra" :icon_biggrin:
Could that be achieved by replacing the 500K pot with a switched pot or push pull pot? Would prefer to not drill anymore holes in the chassis if possible, just not sure how to implement that with a pot. I don't have much experience with push pull pots.
I'd be fine with anything from 25K-250K on the raw control if I could implement the bypass. Basically something to just break the ground connection on the tonestack. Unless I am thinking wrongly.
Re: Princeton tonestack bypass wiring question
« Reply #1 on: April 24, 2023, 07:22:27 pm »
Remove the ground from the bottom of your raw pot. Now put a switch between the raw pot and ground.
Offline bmccowan
  • Better builder than player
« Reply #2 on: April 24, 2023, 07:33:11 pm »
He's not wanting another hole in his head - er, chassis. Would this pot work?
https://www.amplifiedparts.com/products/potentiometer-alpha-audio-spst-rotary-switch-500k
Mac
John Prine
« Reply #3 on: April 24, 2023, 07:46:01 pm »
Push/pull switched pot would be better.
Offline jordan86
« Reply #4 on: April 25, 2023, 12:00:33 pm »
So I think I know how to do it. I would need a push pull that is closed in the stock position and switch open in the pulled position. Is that normal? Or are they always open in / closed pull?
« Reply #5 on: April 25, 2023, 12:16:03 pm »
The pots with a SPST switch are usually closed in the pull position. But if you get a pot with a DPDT switch you can wire it either way.
     https://www.tubesandmore.com/products/potentiometer-bourns-audio-knurled-shaft-push-pull-mini
Offline nandrewjackson
« Reply #6 on: April 25, 2023, 02:27:08 pm »
Isn't at least some resistance to ground necessary at that point?
Is that EQ after a cathode or anode follower?
Offline jewishjay
  • Merrily on my way to nowhere in particular!
    • my Reverb store
« Reply #7 on: April 25, 2023, 02:35:43 pm »
Only if you want the tone controls to work. By disconnecting the tone controls from ground, it takes the tone stack out of circuit, giving a huge volume gain boost. Hence "raw" or direct sound.
« Reply #8 on: April 25, 2023, 03:10:52 pm »
I see, there's a volume control there in the Princeton reverb.
I think I'd plan on switching in a 3Meg resistance to ground under the raw control lug to ground point.
Minimize a possible "pop" from the switch?
Offline jordan86
« Reply #9 on: April 25, 2023, 04:18:10 pm »
I don’t plan to hot swap it or use it live on the fly. Just studio and home use.
« Reply #10 on: April 25, 2023, 09:25:21 pm »
I like it better to install a mini pot in the #2 input and wire it to the bass pot as described as a variable tone stack bypass.  Some of the intermediate positions of the pot are useful to me.
YMMV
