September 16, 2026, 12:02:58 am
Hoffman Amps Forum image Author Topic: 135w UL Vibrosonic, plate voltage tanking, help!  (Read 7061 times)
Offline BluegrassDan
« on: April 30, 2023, 07:37:22 pm »
Been working on a 1977 135W ultralinear Vibrosonic that has been a real nightmare.
What might cause the plate voltage to drop significantly during warmup? All pin 3s measure around 500v then drop down to 3v after a few seconds. The UL taps stay at 500v. Bias is running 50ma, which is too hot.
New Hammond OT, wired for UL. New tube sockets. Everything appears to be wired correctly. Tubes test good and work fine in another amp.
Re: 135w UL Vibrosonic, plate voltage tanking, help!
« Reply #1 on: April 30, 2023, 07:55:57 pm »
Bad OT. Wiring error.
Offline Latole
« Reply #2 on: May 01, 2023, 04:11:51 am »
Vibrosonic Reverb 135 watts schematic is same a the Twin reverb 135 watts ultralinear
Or I' wrong ?
« Reply #3 on: May 01, 2023, 10:54:01 am »
It’s the same, except the output wiring is a bit different for 8ohm configurations.
« Reply #4 on: May 01, 2023, 11:47:55 am »
Seems weird, what’s the bulb wattage in your light bulb limiter, how brightly is it lighting?
Take the valves out until you can prove the sockets can provide them with suitable voltages.
Offline tdvt
« Reply #5 on: May 01, 2023, 02:47:56 pm »
Have you found this schematic below already?
Many thanks to Delrefugio Amplification for drawing it. I more or less used this to rebuild my UL Pro Reverb, as it is actually readable.
The Fender schematic from that era is a confusing nightmare.
Offline Latole
« Reply #6 on: May 01, 2023, 02:58:40 pm »
You are right ; here the original
Offline AlNewman
« Reply #7 on: May 01, 2023, 06:30:34 pm »
All 4 tubes?
I'd be suspicious of the matching pot or the 33k resistor.
Is it all stock?
Offline Latole
« Reply #8 on: May 02, 2023, 02:20:58 am »
All 4 tubes?
Is it all stock?
It is original , look Fender schematic
« Reply #9 on: May 02, 2023, 07:42:56 am »
I can't think of any fault that fits these symptoms. Are you very sure of the voltage readings?
« Reply #10 on: May 02, 2023, 12:34:11 pm »
An unsoldered joint at OT CT *might* power-up a voltmeter probe and go open when the 6L6es start sucking. But I also favor misreading or misreporting.
« Reply #11 on: May 03, 2023, 01:40:17 pm »
What voltage on Pin 5 with the output tubes pulled out?
