September 16, 2026, 01:08:22 am
Hoffman Amps Forum image Author Topic: Fender Vibrochamp 1979 problem... sounds like delay decay  (Read 5418 times)
Offline fpolak
« on: May 03, 2023, 06:45:15 pm »
Hi guys,
I have a Fender vibrochamp 1979 with a strange problem. it sounds like a delay when volumes goes off and distorted. it is perceived more with a low volume 4/5.
This is not a tube problem (I replaced all) and not vibrato problem, because i put off vibrato tube and problem persist. All electrolitics caps and tone was changed for sprage atom few years ago.
I dont know what to test...  I upload video with this problem
eature=share
« Last Edit: May 03, 2023, 07:03:25 pm by fpolak »
Offline AlNewman
Re: Fender Vibrochamp 1979 problem... sounds like delay decay
« Reply #1 on: May 03, 2023, 07:59:20 pm »
You could try setting up a listening amp and go from there.
Offline fpolak
« Reply #2 on: May 03, 2023, 08:15:59 pm »
How can I do this?
Offline AlNewman
« Reply #3 on: May 03, 2023, 11:45:41 pm »
http://musicfromouterspace.com/analogsynth_new/HOT_TIPS/images/amp_signal_tracer.gif
Build that, but use a 630v or higher cap instead of a 50v cap on the signal side.  Then plug it into another amp and start listening, starting at the front of the chain and working towards the back.
Adjust volumes every time you change connections, and be careful of high voltage.  A set of clip on probes is really helpful, and at the very minimum use standby whenever you change connections.
« Reply #4 on: May 04, 2023, 12:18:28 pm »
Besides tube swap*, 1st things to check are power supply voltages at each filter cap and plates, screen, cathodes. Need to know if any of these look ‘odd’, which might give clues about if/where parts are failing.
*did you try swapping all tube’s (including rectifier)?
Also, you say filter caps were changed ‘a few years ago’, but what else has been done to the amp? (Rewiring?, modifications?).
« Reply #5 on: May 04, 2023, 12:36:53 pm »
The video reminds me of the ‘knackered speaker’ syndrome.
