September 16, 2026, 03:56:38 am
Hoffman Amps Forum image Author Topic: Uneven/unbalanced heater voltage  (Read 5821 times)
Offline Duncan
  • I used to play guitar.
« on: May 04, 2023, 01:23:54 pm »
Hey guys,
I’m in the last stages of getting a new build up and running (sort of a unique take on a jcm800 circuit) and I am noticing on my heaters, I’m getting about 3.4 VAC on one side and about 6.5 VAC on the other.
Has anyone seen this before?
From what I can tell, everything is wired correctly, and I am at a loss.
Thanks in advance!
Re: Uneven/unbalanced heater voltage
« Reply #1 on: May 04, 2023, 02:04:05 pm »
are you using resistors to make a CT with the filament supply?
if so, verify both R's are the same value----with a meter
Offline Duncan
« Reply #2 on: May 04, 2023, 02:06:57 pm »
Nope. The PT has a centre tap that I’m currently running to ground.
« Reply #3 on: May 04, 2023, 02:17:36 pm »
To correctly measure heater voltage measure from pin to pin on the tube socket, not from pin to ground. IOW, one probe on pin 2, the other probe on pin 7. Or, one probe on pin 4/5 and the other probe on pin 9.
Offline Duncan
« Reply #4 on: May 04, 2023, 03:22:36 pm »
Measured pin to pin, got about 3.5 VAC
« Reply #5 on: May 04, 2023, 03:37:32 pm »
Maybe the CT has somehow been mixed up with a winding end?
Offline Duncan
« Reply #6 on: May 04, 2023, 03:55:47 pm »
Well shoot. I just reviewed the wiring diagram for the transformer and that’s exactly what I did. Turns out the winding leads are black and orange, and the CT is brown.
Facepalm central.
Thanks!!
