September 16, 2026, 05:22:11 am
Hoffman Amps Forum image Author Topic: 6G7A Bandmaster Tremolo Noise?  (Read 4953 times)
Offline jazjamr
« on: May 09, 2023, 07:58:30 am »
At idle with all pots at 0, my '63 Bandmaster has a shhhh  shhhh  shhhh noise. Obviously it's related to the harmonic trem. Any ideas?
Offline Bieworm
  • I like it loud!
Re: 6G7A Bandmaster Tremolo Noise?
« Reply #1 on: May 09, 2023, 08:31:44 am »
Not necessarily the trem causing this. If you have a lot of idle noise of some kind, the trem might also just indicate of attenuate that when wiggling. Does it always do that? Or what’s the deal without trem engaged?
« Reply #2 on: May 09, 2023, 08:55:25 am »
I would start by changing V5. Use a low noise tube such as 7025 or 5751.
Offline jazjamr
« Reply #3 on: May 10, 2023, 07:43:10 am »
Checked tubes yesterday. V5 was OK, V6 phase inverter was very noisy. Replaced JJ Ecc803 with ANOS Sylvania. Replaced RCA 12AX7A in V2 With TAD E83cc. RCA was microphonic. Tremolo RCA jack wasn't making good ground contact. Removed and cleaned chassis and jack with DeOxit. Tremolo is in operation mode with RCA jack ungrounded. Cleaned and grounded RCA plug turns it off. I had always used a footswitch to operate tremolo ,and was mistaken about it's operation. I acquired this amp in 2000. It was found in the garage of a rental house, that had been used to paint cars. Amp had been on fire, output transformer was dead, cloth covered wire jacket was crumbling, Blonde Tolex was painted black. All wire was replaced with appropriate cloth covered wire, output transformer was  replaced with an Allen amps trans. All electrolytic caps replaced, Tolex cleaned. Chassis was already punched for a rectifier tube. I added a 5U4 to lower B+ voltage. The amp is certainly not a collecter piece at this point,  but the harmonic vibrato is wonderful.
