August 29, 2026, 08:26:16 pm
Hoffman Amps Forum image Author Topic: SE Amp Project  (Read 5822 times)
Offline Rontone
  • Ixnay on the Ampscray
SE Amp Project
« on: May 16, 2023, 07:01:13 am »
I have a few salvaged parts that I would like to put into a little champ style SE build,
The mains transformer would be 250-0-250 running though diode rectifier so about a 350V HT
The output transformer has a centre tapped primary at 3400 ohms and was set up push pull, I have seen 3000-8000 as figures for 6V6 single ended and thought it may be possible at first, but then also read about P-P output transformers not being great for single ended as the cores are different and can restrict power or other magnetizing/saturation problems
The O/T had about 15w on it set up as push pull, its very chunky and dense so I wonder if a 6V6 running at a low wattage would pass through it,
Is it worth a try, or will it smoke and fry?
Re: SE Amp Project
« Reply #1 on: May 16, 2023, 07:52:08 am »
I see Smoke & Fry far from your scenario but weak result about quality of sound
may be with 2 or 3W of output the situation will be a bit better
Offline Rontone
Re: SE Amp Project
« Reply #2 on: May 16, 2023, 11:25:32 am »
I might as well get rid of it and get the correct SE 6V6 one for a champ really, I'm looking at the AA764 Champ style circuit, with a treble and bass control,
I see a 5000 ohm OT to run with a 6V6 at Primary Windings UK so that should work nicely,
I presume those type of Champs were a 4 ohm speaker?
Re: SE Amp Project
« Reply #3 on: May 16, 2023, 12:19:59 pm »
I see a 5000 ohm OT
an OT has 2 spec's the primary as you stated, AND a 2ndary value.  you match the speakers impedance to the OT's secondary impedance value, you get the primary value
Offline Williamblake
Re: SE Amp Project
« Reply #4 on: May 16, 2023, 01:23:17 pm »
Why would you use a push pull OT for SE? They are different for a reason. Get an SE OT from an old radio.
Offline Rontone
Re: SE Amp Project
« Reply #5 on: May 16, 2023, 03:31:01 pm »
Yeah, I was just checking, I was hoping at first it may be as simple as omitting the CT but now see why they cannot, and yes I have seen some radio OT's on eBay, unsure of the wattage but will keep checking
The primary windings UK OT's are a bargain so may just get a new one for it
I was thinking if I follow the Fender AA764 schematic, the feedback resistor [2700 ohm] will need changing as I mostly have 8 ohm speakers so would attach the feedback on that tap, reading in Merlin's Guitar Preamp book I think it may need to go up by √2 to 3900 ohm ish?
Re: SE Amp Project
« Reply #6 on: May 16, 2023, 04:26:21 pm »
SE OTs don’t go for much more than shipping. Knock yourself out. Plenty of good reading and advice on this forum.
Offline AmberB
Re: SE Amp Project
« Reply #7 on: May 16, 2023, 11:15:23 pm »
I see no reason why you couldn't use an output transformer that's rated for an 8 ohm output load in the AA764 circuit.
