August 29, 2026, 08:28:58 pm
Hoffman Amps Forum image Author Topic: Line out Issue  (Read 5360 times)
Offline BrainDeadAmps
  • Trial and error
Line out Issue
« on: May 16, 2023, 01:38:01 pm »
I'm building a single ended "fenderish" SE Amp. I've never really messed around with Line outs, and decided i'd try it to experiment with running the amp as a pre-amp to drive another amp.
The line out voltage divider was lifted from the "Dizzy Bird" schematic posted on the amp garage.
I finally tested it today and with the internal Speaker still connected to to the amp (#1), running the line out to the input of amp (#2).
With Amp #1's L/O connected to the input jack of Amp #2 with the vol all the way off, I can hear Amp #1 like normal through the internal speaker. When I turn up Amp #2's Vol even just a little bit, the internal speaker through amp#1 cuts out and now Amp#1 is only heard through Amp#2
Where did I go wrong?
« Last Edit: May 16, 2023, 03:05:44 pm by BrainDeadAmps »
Re: Line out Issue
« Reply #1 on: May 16, 2023, 02:16:57 pm »
I'm guessing it's not wired like the schematic you posted. Or maybe you're not telling the whole truth.
  • Trial and error
Re: Line out Issue
« Reply #2 on: May 16, 2023, 03:10:10 pm »
Sluckey, I know it looks like a mess but that's how it's wired. I'm building it as a small combo and have never really used line outs before now.
I know my inicial post is confusing but amp#2 i'm referring to is a small s/s amp.
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
Re: Line out Issue
« Reply #3 on: May 16, 2023, 04:35:33 pm »
Hola amigo,
I have built a small SE rocking amp, low wattage that I use as a preamp to drive a50 watt amplifier and  it works great.  The important I think is to use a transformer to isolate both amplifiers.  If you go to the JENSEN transformers site, you ll find many transformers, their application  and  lots of schematics.
There is one called:  tube amp line out.
Hope that helps
Colas
P.S.: call me Alvin.
Re: Line out Issue
« Reply #4 on: May 16, 2023, 04:49:18 pm »
Try it with a tube amp. There's nothing on your schematic that should cause that symptom.
