September 16, 2026, 05:24:00 am
Hoffman Amps Forum image Author Topic: Weird power amp wiring  (Read 4648 times)
Offline Leevi
    • Rikstone
« on: May 22, 2023, 09:42:28 am »
What is the idea of the following power amp wiring?
The cathodes and screens are connected to the OT instead of plates and the CT is grounded.
/Leevi
« Last Edit: May 22, 2023, 10:30:08 am by Leevi »
Offline Williamblake
Re: Weird power amp wiring
« Reply #1 on: May 22, 2023, 11:57:08 am »
Negative screen sag? Building a hifi amp? More impulse current? Less compression?
« Reply #2 on: May 22, 2023, 12:58:26 pm »
The OT secondary provides some resistance for bias voltage (mixed), and feedback, probably negative.
There’s a Leslie with something similar.
Also seems something weird with the rectifier common return via the OT secondary half winding.
« Reply #3 on: May 22, 2023, 04:13:35 pm »
The plates ARE connected to OT... through the DC supply.
It is essentially a McIntosh with the complexity moved from OT to power supplies.
Or the ElectroVoice competitor to the Mac.
