September 16, 2026, 04:28:31 am
Hoffman Amps Forum image Author Topic: Fender Hotrod reverb deluxe combo B+ filter cap bad now bias drifting  (Read 4214 times)
Offline marshallguy
  • Failure is not an option
Hi, I replaced an open B+ 500v/ 47uf cap with a FET brand on my friends hot rod deluxe combo amp. Everything was good, B+ 430vdc and I checked the bias which went from 60 to 70mv after warm up but stabilized. The Power tubes are Sovtek 6L6WXT+. He said the amps about 15 yrs old and the tube over 10 but he hardly ever uses it. I figured any where between 60 to 70 mv is good with a 30w each pair of tubes though Fender wants cold bias at 60mv a pair. I don’t know what the stock tubes were in this amp or their wattage rating.
Anyway, I’m playing the damn thing for about 10 mins on low volume and explaining the the 2 channels adjustments and such, switching back and forth and suddenly the power starts to drop out and a hum shows up even after I unplugged my guitar!
After turning it off, I recheck the same filter cap and it’s reading about 44uf. Hmmm, ok, not open but not 50uf. I also checked the other B+ rail caps, all good. I turn it back on, hum is gone and I recheck the bias to show him and the bias goes from 60 to 70 in short orderthen to 75, 76, I turn it off before it keeps going and going up. Not good.
So is it now a bad bias filter cap or one maybe just of the the power tubes that’s the probable cause? Unfortunately one can’t easily determine which tube is drifting up or if it’s both together.
Could a bad power tube take out a B+ rail filter cap?
Reposted per instruction from admin wrong board before.
JC
