September 16, 2026, 05:23:11 am
Hoffman Amps Forum image Author Topic: 30ish watt bass amp  (Read 7697 times)
Offline Beezerboy
30ish watt bass amp
« on: May 27, 2023, 01:41:35 am »
I want to build a bass amp for a friend. looking for something in the 30-40 watt range. probably a combo, and as light as is realistic. I search for demos on tube bass amps and mostly I get guitar guys playing through bass amps. this is for a bass... for a guy that can really play the bass.... for the last 50 years.... play the bass, for a living... its all he does
what else is there besides the 5F6A?    and, I would prefer single channel, single input.... straight up fat tube amp
« Last Edit: May 27, 2023, 01:46:13 am by Beezerboy »
Offline Latole
Re: 30ish watt bass amp
« Reply #1 on: May 27, 2023, 02:43:22 am »
 5F6A  Fender Bassman is a good choice . Layout and schematic are available.
Offline tdvt
« Reply #3 on: May 27, 2023, 05:43:25 am »
Speaking as a bass player myself, the B-15 is a great suggestion. An iconic bass amp.
Further, a single-channel version, in a combo with a NEO speaker, would make a killer portable set-up.
I am surprised that configuration isn't already a thing out there (unless it is & I haven't heard of it..)
I was always a 15" guy but currently, & happily, play through a 12" KAPPALITE 3012LF. Sometimes X 2, but usually just one.
Less heavy, sounds great.
Offline tdvt
« Reply #4 on: May 27, 2023, 05:46:29 am »
If your friend is full-time, it wouldn't surprise me if he already had some iteration of a B-15.
But you have me pondering a new project....
Offline Beezerboy
« Reply #5 on: May 27, 2023, 05:19:53 pm »
He's got a Hartke rig for his main amp. he always talked about some cabinet with 4 tens that he liked. I'm thinking maybe 2 tens in a combo. 25-35 watts is plenty for the small venues we have around here. I made him a lightweight (hollow) P bass last year because his 5 string Smith is just too heavy for an old man
yeah.... the B-15 deserves a look. thanks
« Reply #6 on: May 27, 2023, 05:41:35 pm »
I vote for a B15 Porta flex  and older one ..   they are outstanding.. and very portable.
Or even something like this..    https://reverb.com/item/62570898-ampeg-sb-12-portaflex-2-channel-25-watt-1x12-fliptop-guitar-combo-1965-1971-black
« Last Edit: May 27, 2023, 05:44:34 pm by mresistor »
Offline Beezerboy
« Reply #7 on: May 27, 2023, 06:19:43 pm »
look what I found....
https://www.talkbass.com/threads/b-15-clone-build.1185039/
I wouldn't be building it to look like the original, so the trannys only need to match the circuit. the OT he uses is a Hammond 1650HA because he says that the one that matches... can't seem to find that one
Offline Beezerboy
« Reply #9 on: May 27, 2023, 08:49:12 pm »
thanks! I forget about those Hawk guys. they have the stuff, and seem to have the good prices.
Offline AmberB
« Reply #10 on: May 27, 2023, 10:30:09 pm »
You could use the transformers from a Bogan CHB-35A and change the tubes from 7868s to 7591s, same out put transformer spec for both tubes.  Ampeg used the 7591s in a few of their amps.
I can't say how available those Bogan tube PA amps are these days, but I've converted several of them to guitar amps.
A B-15 clone would be a pretty good small bass amp.
I played bass through a Fender silverface Bassman 50 for a lot of years.  I also had a Bassman 100, but it had more power than needed for the size of most of the venues that we played in.  I used the 50 watt amp with a 1-15 Musicman cabinet, it did the job.
Offline Lectroid
« Reply #11 on: May 28, 2023, 09:21:52 am »
@AmberB,
I'm wondering about a Bogen CHB-20B to be a donor patient.  With the ECL86, it looks to put out  around 8-10W.  Any experience with one of those?
No, cancel that.  Once I searched here, I found lots of Bogen threads.  Price is right so it might be worth the gamble.
« Last Edit: May 28, 2023, 10:04:58 am by Lectroid »
Magis bos clocca!
Free Beer Tomorrow!
« Reply #12 on: May 28, 2023, 09:32:52 am »
Interestingly  in the CTG parts list they reference Weber Transformers and of course they are less expensive
http://ctgelectronics.weebly.com/custom-amplifier---fcbn-51b.html
PTW022798
WOT45
« Last Edit: May 28, 2023, 10:27:46 am by mresistor »
Offline AmberB
« Reply #13 on: May 28, 2023, 03:36:22 pm »
@AmberB,
The ECL86 tube can put out 18 to 20 watts in push pull.  I modified A CHB-20 to guitar amp configuration and it sounded good and got pretty loud through a 12 inch speaker.  I have another CHB-20 chassis that needs a proper power transformer.  The PT had been replaced before I got it and the voltage was too high for the ECL86 tubes.
Offline Lectroid
« Reply #14 on: May 29, 2023, 03:26:16 pm »
Did your guitar conversion run the B+ at about the same levels  (A = 400V, B=375, etc?)  as the stock PA amp?
Did you add grid blocking and/or screen blocking resistors to the power tubes?
Magis bos clocca!
Free Beer Tomorrow!
Offline AmberB
« Reply #15 on: May 29, 2023, 09:28:19 pm »
I used the stock voltages for the amp.  I don't remember if I put in any grid or screen resistors.
I modified the preamp section to approximate the Ampeg Gemini II preamp.  I know there's a couple of threads on this forum about the CHB-20, one of them being the thread that I started.
Offline Lectroid
« Reply #16 on: May 30, 2023, 08:19:17 am »
I'll look for those.  Thanks!
Magis bos clocca!
Free Beer Tomorrow!
