September 16, 2026, 10:21:14 am
Hoffman Amps Forum image Author Topic: small chassis layout  (Read 5780 times)
Offline joesatch
  • save me from myself.
« on: May 29, 2023, 10:27:15 am »
Putting this very small power amp together. The chassis is a hammond 7x7.  Is there a rule about proximity of the input jack , speaker jack to the OT or PT (or input jack to speaker jack proximity)?  My plan is to have the input jack and speaker jack on the rear , The rear has both the PT and OT mounted next to each other.
Offline thetragichero
Re: small chassis layout
« Reply #1 on: May 29, 2023, 10:30:35 am »
best practice is input jack as far away from output jack and transformers as feasible. if it's just a power amp you'll probably be fine because you're not amplifying sub-volt signals (expected input is likely a volt or more)
Offline joesatch
« Reply #2 on: May 29, 2023, 10:44:52 am »
i might mount the input jack right over the P.I. on the front. Not what i wanted but i dont want headaches. I suppose i could build it all and wire the input jack on a coax wire and move it around to see if there are noise issues before i drill and mount it
« Reply #3 on: May 29, 2023, 10:58:31 am »
I suggest this...
Offline joesatch
« Reply #4 on: May 29, 2023, 11:09:42 am »
thanks ya i guess i'll go that route. might use one of these.
« Reply #5 on: May 29, 2023, 11:12:16 am »
Another space saver. Good idea.
Offline joesatch
« Reply #6 on: June 04, 2023, 02:01:23 pm »
looks like we're in business. I've incorporated the hum-loop block network.
Offline joesatch
« Reply #7 on: June 04, 2023, 02:55:03 pm »
only question now is do i need to drill some ventilation holes in the chassis. these diecast hammond boxes seal up pretty well.
« Last Edit: June 04, 2023, 02:58:30 pm by joesatch »
« Reply #8 on: June 04, 2023, 07:15:03 pm »
That's what us southern boys call 10lbs of shit in a 5lb box.    :thumbsup:
