September 15, 2026, 11:07:25 pm
Hoffman Amps Forum image Author Topic: Parallel triode Rg values  (Read 4265 times)
Offline Esquirefreak
« on: June 01, 2023, 12:49:19 pm »
Hi, all.
Haven't built anything in quite a while. Struggling with life in general made spring time rough. You know how the song goes.
Anyhow:
I gutted one of my amps, cause I thought I'd build something. A single channel 5F6A, but with the first two triodes in parallel, one VOL pot and a single pair of HI/LO inputs.
My question is - do I simply cut the grid stopper values (coming from the input) in half? That is 2*33k resistors instead of the usual 2*68k resistors. I haven't messed around with parallel triode stages before.
Best regards from Sweden,
Max
Re: Parallel triode Rg values
« Reply #1 on: June 01, 2023, 12:50:35 pm »
Yes
« Reply #2 on: June 01, 2023, 01:12:43 pm »
Here's an example using Hoffmans single channel DR
 https://el34world.com/Hoffman/files/Hoffman_AB763_1.pdf
scroll down to the schematic and look at the input
« Reply #3 on: June 01, 2023, 01:42:27 pm »
Thumbs up for the help. Thanks!
/Max
