September 15, 2026, 02:30:26 pm
Hoffman Amps Forum image Author Topic: Phase inverter with EF86  (Read 5382 times)
Offline Leevi
    • Rikstone
« on: June 07, 2023, 01:43:25 am »
I have a need to invert phase in a EF86 preamp.
Are there some good practices to do that without increasing the amplification?
The available resources for that are 1/2 12AX7 and EF86.
/Leevi
Re: Phase inverter with EF86
« Reply #1 on: June 07, 2023, 02:46:19 am »
Use the triode as CF
it will invert the signal in exit from the ef86
Offline Leevi
    • Rikstone
« Reply #2 on: June 07, 2023, 04:16:18 am »
Hi Franco, do you have an example?IMO cathode follower does not invert the phase.
/Leevi
« Last Edit: June 07, 2023, 04:27:22 am by Leevi »
Offline Leevi
    • Rikstone
« Reply #3 on: June 07, 2023, 06:21:17 am »
This works
/Leevi
« Reply #4 on: June 07, 2023, 06:53:52 am »
My fault, you are right
however you can solve with the same triode, arrange an anode follower with 1 or less of gain (if you don't want it)
may be you can have the same result using a mosfet instead of to add a triode
« Last Edit: June 07, 2023, 07:03:48 am by kagliostro »
Offline astronomicum
« Reply #5 on: June 07, 2023, 08:46:28 am »
/Leevi
The Univox U-1221 uses a cathodyne (unity gain) after the pentode in the PI position. They used a 6AN8. May provide an option.
« Reply #6 on: June 07, 2023, 10:26:45 am »
If I've understand correctly Levi want only to invert the signal, not to have a phase inverter to drive a PP Power section
However using one of the exit of a concertina can give the wanted result
« Reply #7 on: June 07, 2023, 10:36:14 am »
This works
/Leevi
Yes. The cathodyne is the simplest way to get inversion with no gain. Ignore the cathode output. You could replace the plate resistor with a pot if it's important to adjust the gain to exactly 1.
Offline Williamblake
« Reply #8 on: June 07, 2023, 10:37:36 am »
You could use a signal output transformer with enough connections, it would give you any phase you want and also provide galvanic isolation which might be a very nice thing to have in a preamp.
Offline Leevi
    • Rikstone
« Reply #9 on: June 07, 2023, 11:06:51 am »
Yes, I'm going switch two preamp channels together and I want that the signals are in same phase.
EDIT: A common input is used for both channels  (A and B) and you can switch between  A, B and A+B
/Leevi
« Last Edit: June 07, 2023, 11:19:05 am by Leevi »
Offline isaac_teller
