September 23, 2026, 10:17:29 am
Hoffman Amps Forum image Author Topic: 6G6B Treble Potentiometer Question  (Read 6838 times)
Offline 72Blazer
  • Long live rock!
« on: June 09, 2023, 06:26:48 pm »
Is there anything special about this pot?  I see it is a 350k pot but The 70k Tap has me confused.
Vr
J
Re: 6G6B Treble Potentiometer Question
« Reply #1 on: June 09, 2023, 06:49:05 pm »
Yes. It has a 70K tap. That means four lugs. That also makes it special.
It was used for a short time during the reign of the 6Gxx amps, then abandoned. Hard to find now so that also makes it special.
« Reply #2 on: June 09, 2023, 07:54:21 pm »
... I see it is a 350k pot but The 70k Tap has me confused. ...
WeberVST must have paid Alpha a long while back to re-make those pots.  AFAIK, they are one of the few (only?) places to find a 350kΩ pot tapped at 70kΩ
Offline 72Blazer
  • Long live rock!
« Reply #3 on: June 09, 2023, 08:10:51 pm »
Thanks Sluckey and Hot Plate.
Confirm this would in fact work?
« Reply #4 on: June 09, 2023, 08:31:25 pm »
It is an old MONO loudness pot. When stereo arrived, these were a bit of a glut on the market. Fender found a use, good for them, but it is a historically dead-end part. And not easy to fake. Get the Weber part, while you can, IF you think this tone-network is what you want. It IS made for the Fender application.
« Reply #5 on: June 09, 2023, 08:40:02 pm »
What do you think?
Offline 72Blazer
  • Long live rock!
« Reply #6 on: June 10, 2023, 07:35:02 am »
I'm gonna give it a shot.  Thanks all.
Offline AlNewman
« Reply #7 on: June 11, 2023, 12:06:33 pm »
I see tapped pots quite often in radios where they combine a volume and tone circuit.
How does this example work?  Is it basically a standard fender tone stack, until the treble hits 20% rotation, then the two caps work in parallel providing a bass boost?
Offline AlNewman
« Reply #9 on: June 12, 2023, 08:55:01 pm »
That is pretty interesting.  Must be suited for jazz or something.
