September 20, 2026, 12:07:12 pm
Hoffman Amps Forum image Author Topic: Deluxe Reverb without Reverb  (Read 5554 times)
Offline roseblood11
    • Layouts and Pictures
« on: June 22, 2023, 09:44:05 am »
Hi,
I'm planning to build a one channel amp, that has exactly the sound and gain structure as an AB763 Deluxe Reverb - but WITHOUT THE REVERB. How should I modify the circuit? Leave the 3.3M, 10p and  the 150k to gnd ( = 470k and 220k in parallel) in place? What would you recommend?
http://www.brieskorn.de/Guitar___Amps/Verstarkerprojekte/AB763/circuit_mod.pdf
« Last Edit: June 22, 2023, 09:46:28 am by roseblood11 »
Offline labb
Re: Deluxe Reverb without Reverb
« Reply #1 on: June 22, 2023, 09:59:36 am »
Take a look at this. should give you an idea of how to procede. Princeton Reverb Delete (robrobinette.com)
« Reply #2 on: June 22, 2023, 01:01:32 pm »
Hi,
That schematic doesn’t have tremolo but has a type 4 master volume and a switched bright cap with much higher value (labelled presence).
It may be a good idea to list all the features you want.
Offline tdvt
« Reply #3 on: June 22, 2023, 01:28:18 pm »
Agreed, as there are many well documented versions of single channel Fender circuits already out there, some with little extras (or not)
RobRob's BLACKVIBE is an an AB763 with no trem & no reverb. To me, this design seems like a nice clean starting point & I believe it has also undergone a few versions-worth of sorting.
BLACKVIBE LINK
Offline Esquirefreak
« Reply #4 on: June 22, 2023, 01:43:43 pm »
Another option is to build a single "normal" channel Bassman AB165 with a AA864 power section. A pot/divider between the 2nd and 3rd stage and a type 2 MV after the PI makes for a very versatile amp. I build one like that for a friend.
/Max
« Reply #5 on: June 22, 2023, 02:10:17 pm »
If you may be interested in a single channel (normal channel) Deluxe AB763 look at this...
     http://sluckeyamps.com/misc/AB_Lite_II.pdf
