September 19, 2026, 08:15:40 pm
Hoffman Amps Forum image Author Topic: Amp Rear Panel Labeling — Suggestions?  (Read 5638 times)
Offline thud33
  • amp love & hearing loss
« on: June 27, 2023, 08:18:44 am »
I have installed a rear panel rotary switch on a 1976 Marshall JMP 2204, replacing the original (and problematic) two pin plug & socket selector. I am very happy with the outcome, but I am thinking about a good way of labeling the impedance options. A simple “4”, “8” and “16” (going from 7 to 9 to 11 o’clock) would be fine. Ideas / best practices? Thanks!
{edit- title typo-- PRR}
« Last Edit: June 27, 2023, 01:27:56 pm by PRR »
Re: Amp Real Panel Labeling — Suggestions?
« Reply #1 on: June 27, 2023, 09:22:52 am »
I use a DYMO Label Maker with black type on a clear label. Very easy to use.
     https://www.amazon.com/DYMO-LabelManager-Label-Maker-1768960/dp/B00464E5P2/
Here's a sample...
Offline thud33
« Reply #2 on: June 27, 2023, 09:39:12 am »
Thanks sluckey! Any particular type of label stock that sticks best to brushed metal?
Offline acheld
« Reply #3 on: June 27, 2023, 09:52:35 am »
I think the clear tapes are all polyester.   I've used both branded (Dymo Industrial) and knockoff, and they both work about the same.
For brushed metal, I think the vinyl tape sticks better, but it is not clear, and I do like the clear tape better.
For a professional appearance, nothing beats the look -- or the cost -- of Front Panel Express.
Offline thud33
« Reply #4 on: June 27, 2023, 09:57:45 am »
Thanks for the details and for sharing your experience. Much appreciated!
« Reply #5 on: June 27, 2023, 10:01:37 am »
You'll have to use the labels that are made for your printer. Clean the area where the label will go with alcohol. DYMO labels will stick to brushed metal finish.
Re: Amp Rear Panel Labeling — Suggestions?
« Reply #6 on: June 27, 2023, 01:34:15 pm »
The BROTHER label makers work for me, for houselight switches and network cables. The latest and perhaps more expensive models will take PC-generated art. I now have three bought in yardsales that don't do PC and just print alpha-numbers and a few icons. Even in bathroom lightswitches (rubbed many times a day in damp room) I have not had trouble with rub-off.
"My latest" is a Brother P-touch D210 from 2001. Discontinued but the manual is still on Brother's site. Why a manual? I know my PT1830 very well, and have another, but turns out each model has different frills (for different price-points). The D210 has multiple fonts plus pages of icons. The 'electrical' could even be of use here.
« Last Edit: June 27, 2023, 02:05:23 pm by PRR »
Offline dwinstonwood
« Reply #7 on: June 27, 2023, 02:56:13 pm »
I use this old thing at work.
Offline thud33
« Reply #8 on: June 28, 2023, 06:06:49 am »
Sluckey, PRR, dwinstonwood — many thanks for the suggestions!
Offline Bieworm
  • I like it loud!
« Reply #9 on: June 28, 2023, 11:56:21 am »
