September 19, 2026, 06:06:07 pm
Hoffman Amps Forum image Author Topic: Epiphone Regent (ea-16rvt) schematic question  (Read 4705 times)
Offline yorgle
« on: June 28, 2023, 11:49:50 am »
Greetings amp folks- can someone help with a quick schematic question?  Looking at the 20uf filter capacitors (c22-c25) for this Epiphone ea16rvt (see below), is the center tap the negative side for all of these caps?
Re: Epiphone Regent (ea-16rvt) schematic question
« Reply #1 on: June 28, 2023, 12:43:52 pm »
No. The center tap is the common ground. C22A, C22B, C24A, and C24B negative side will connect to the center tap. But, C23 and C25 ***POSITIVE*** side will connect to the center tap.
Offline yorgle
« Reply #2 on: June 28, 2023, 02:45:36 pm »
Thanks much!
