September 19, 2026, 07:03:50 am
Hoffman Amps Forum image Author Topic: Sluckey's Dual l lite new build "transformer recommendations"  (Read 5639 times)
Offline 72Blazer
  • Long live rock!
I am intrigued by the dual lite (18 Watt/AC15) Sluckey's build and looking for some transformers to fit the bill.  He mentions doing an AO-39 conversion but can't seem to find that particular set of transformers on eBay-yet I see alot of used iron for sale.  Can anyone point me to what would be a good choice for this build-either old or new production iron?  Thanks!
Vr
J
Re: Sluckey's Dual l lite new build "transformer recommendations"
« Reply #1 on: July 05, 2023, 09:37:27 pm »
Look at the Marshall 18 watt PT and OT. Mojo has them.
See also...   https://www.hammfg.com/electronics/transformers/guitar/18-watt-combo
« Last Edit: July 05, 2023, 11:01:31 pm by sluckey »
Offline 72Blazer
  • Long live rock!
« Reply #2 on: July 06, 2023, 03:02:31 pm »
Sluckey I read you used the Hammond A039 transformers.  Can't seem to locate that.  Any other Hammond organ PT/OT combination do the job here?
« Reply #3 on: July 06, 2023, 04:33:05 pm »
Yeah, those AO-39s and AO-43s were cheap and plentiful until I started turning them into guitar amps!   :l2:
The AO-35 is a good candidate but they are no longer cheap either thanks to Dr. Z.
This Weber transformer set is ideal for any 15 watt EL84 amp...
Offline 72Blazer
  • Long live rock!
« Reply #4 on: July 06, 2023, 05:10:57 pm »
Thanks.  Where did you get your chassis you used as pictured on your website for the "Dual Lite"?
« Reply #5 on: July 06, 2023, 05:46:46 pm »
Chassis came from Watts Audio. He's out of business now. Size is 12.5 x 6.5 x 2.5.
Offline 72Blazer
  • Long live rock!
« Reply #6 on: July 07, 2023, 05:10:07 pm »
Sluckey are you implying the AO-43 would work for the Dual Lite?  If not, what would be a good amp candidate for the AO-43 PT/OT/chassis etc.?
EDIT:  After searching the forum/and Sluckey's web page, I see that this iron would work for a Plexi 6V6.  If it won't work for the Dual Lite, I may build the Plexi 6V6 instead.
Thanks!
Vr
J
« Last Edit: July 07, 2023, 06:04:30 pm by 72Blazer »
« Reply #7 on: July 07, 2023, 09:05:09 pm »
I used AO-43 iron for my Plexi 6V6 and my Supro S-6424. Good results with both amps.
