September 27, 2026, 03:52:32 pm
Hoffman Amps Forum image Author Topic: mosfet cathode follower - tone stack-fxloop buzz  (Read 5907 times)
Offline swingarm
« on: July 12, 2023, 11:25:09 pm »
Greetings all!
I just finished a fender super 5e4a clone (6v6). Sounds great! used an electrohome pa-300 amp as the conversion platform. I decided to put an effects loop in too like the dmars ods using  a cathode follower to drive the tone stack and fxloop, I used a mosfet namely the irfp350. I can hear a buzz at higher volumes and  did trace it to the mosfet. This is my first time using one and used the one from merlin's preamp book. I know most use the 820 but the 350 was on hand. I'm getting 129 volts out. I have 410 on the plates. all the other voltages are close to typical for this design.
 I was wondering if anyone has run into this problem before? Is there any "best" mosfet in these wonderful current times ? Thanks for any input.
« Last Edit: July 13, 2023, 03:06:21 am by swingarm »
Offline Bieworm
  • I like it loud!
Re: mosfet cathode follower - tone stack-fxloop buzz
« Reply #1 on: July 13, 2023, 01:57:53 am »
same old question/remark:
post the schematic for us to get a clear view on what the circuit you built looks like
cheers!
« Reply #2 on: July 13, 2023, 05:14:00 am »
Fender_super_5e4a_schem.pdf (el34world.com)
Yes, please show how you inserted the mosfet cathode follower into that schematic. And also include a few good resolution photos in your post.
Did you use a mosfet so you'd have a triode for the recovery in the FX loop similar to the "Minimalist"?
Are you using a 12AY7 in the V2 position?  If not, what are you using?
Offline swingarm
« Reply #3 on: July 13, 2023, 05:55:24 am »
Hi guys,
yes to both those questions  tubenit.
I made the fx loop circuit  board after the fact.
I will post more pics a little later, thanks!
edit : Did a few things different too. I have cascaded inputs and individual power tube bias pots.
other than that its very close to the original schem. Also the Paul c mod from Rob's site
edit: actually i went off this schematic, but yours is  better. I used Merlin's mosfet follower from his book.
« Last Edit: July 13, 2023, 06:24:03 am by swingarm »
Offline swingarm
« Reply #4 on: July 13, 2023, 06:51:25 am »
Here a few pics. I drew a quick and dirty layout from the schematics. As I said
the fxloop decision came after it was done. Also there is a boost buck switch using the 5volt winding, a triode switch and variable negative feedback too.
« Last Edit: July 13, 2023, 07:10:41 am by swingarm »
Offline swingarm
« Reply #5 on: July 13, 2023, 06:56:38 am »
Here  are a couple more pics. This was a "what I had on hand" build and the donor amp was 125 dollars on Kijiji, not bad.
« Last Edit: July 13, 2023, 07:14:52 am by swingarm »
« Reply #6 on: July 13, 2023, 12:36:19 pm »
Do you have an actual schematic that is a true representation of what you amp is?
Offline swingarm
« Reply #7 on: July 13, 2023, 12:49:53 pm »
Thanks for your help fellas, I will sort this. Just thought I'd throw it out there in regards to the mosfet. Like I say its the super with cascaded inputs and seperate bias controls TUT style, other than tha the effects loop follows the demars. I understand its difficult on your end. Cheers!
« Reply #8 on: July 13, 2023, 09:17:43 pm »
The 'before' schematic takes off from the Treble pot wiper and then goes MANY places. I'm not going to squint the photo to see how much wire is hanging there. But that node is HIGH impedance and really should not be driving many things or much wiring.
I bet if you carefully poke a finger in there "live" (don't get killed) you can make it buzz worse and at many places.
Offline swingarm
« Reply #9 on: July 14, 2023, 07:25:22 pm »
Hey thanks PRR, so that applies to the demars also. no?
« Reply #10 on: July 14, 2023, 08:08:14 pm »
I've not had a problem with mosfet cathode follower & a psuedo FX loop recovery stage on the D'Mars amps I've built.
