August 07, 2026, 08:20:52 am
Hoffman Amps Forum image Author Topic: Hoffman_AB763_1 channel build, output transformer feedback issue  (Read 6809 times)
Offline RoadShow
  • Disturbing the Peace Since 1955
Hello,
I'm wrapping up the Hoffman_AB763_1 channel build and "almost" everything is working great; inputs, volume, tone control, reverb, tremolo...
The issue I'm having is when I hook up the output transformer feedback.  When I do, I get a god awful howl/squeal.  When I pull the feedback wire it goes away and the amp sounds great.  In the attached pictures I have a jumper in place instead of a wire so that I can disconnect it quickly.
Any idea what I messed up?  I've included the AB763 pdf below with the pictures, and I've looked it over several time but am stuck and hoping someone can help me out.
Thanks in advance...
Bill
Re: Hoffman_AB763_1 channel build, output transformer feedback issue
« Reply #1 on: July 20, 2023, 06:42:44 pm »
Swap the OT primary plate leads (blue and brown).
« Reply #2 on: July 20, 2023, 06:48:49 pm »
If OT wires are too short to swap, then swap the two brown grid wires on the board. (see pic)
Offline RoadShow
« Reply #3 on: July 20, 2023, 06:49:41 pm »
Thanks, I kept looking and I was just reading that in your post here, bout halfway down:
https://el34world.com/Forum/index.php?topic=20167.msg211693#msg211693
Offline dogburn
  • Meddling Kid (but older)
« Reply #4 on: July 20, 2023, 07:01:12 pm »
With both amps I have built, I had to switch the OT wires because of the squeal. Fortunately, I was already aware this could happen (I think I read about it at Rob Robinette's site. The lesson should be to get ready to shut the amp off the first time it's all hooked up with a speaker.
Offline RoadShow
« Reply #5 on: July 20, 2023, 07:01:57 pm »
BINGO, thx!!
« Reply #6 on: July 20, 2023, 08:08:55 pm »
BINGO, thx!!
And the take home lesson for this is "DON'T TRIM THE OT PLATE LEADS UNTIL YOU KNOW THE NFB IS CORRECT".
Offline bmccowan
  • Better builder than player
« Reply #7 on: July 20, 2023, 10:11:48 pm »
I just paint the brown lead blue and vice-versa - it's easier.
Mac
John Prine
Offline nandrewjackson
« Reply #8 on: July 21, 2023, 03:30:27 am »
Nice looking build
Offline bmccowan
« Reply #9 on: July 21, 2023, 06:05:50 am »
Wow - that is a very clean build. Well done Roadshow.
And, I like the looks of that jumper - I need to get me some - sometimes alligators just don't make it.
Mac
John Prine
Offline RoadShow
« Reply #10 on: July 21, 2023, 07:46:19 am »
Thx,
Those jumpers are a godsend, great for discharging the caps when I power it off to work on it.
Offline RoadShow
« Reply #11 on: July 21, 2023, 07:47:33 am »
BINGO, thx!!
Yep, 2 lessons learned here.
