September 25, 2026, 09:21:32 am
Hoffman Amps Forum image Author Topic: preamp stage circuit analysis  (Read 7079 times)
Offline joesatch
  • save me from myself.
« on: July 28, 2023, 08:40:11 am »
what is going on here after the 500k volume pot aside from the mute to ground switch?
Offline Dave
Re: preamp stage circuit analysis
« Reply #1 on: July 28, 2023, 09:00:42 am »
A little bit of treble bleed and then nothing.
Dave
« Reply #2 on: July 28, 2023, 09:10:22 am »
Frequencies below about 9Hz get a 4dB boost.
« Reply #3 on: July 28, 2023, 09:17:35 am »
:laugh:
must be a subliminal messaging app
Offline Dave
« Reply #4 on: July 28, 2023, 09:18:12 am »
Maybe I'm looking at it with my morning brain. I realize now that 47nF bleeds about everything, not just treble, but bow does it boost?
Dave
« Reply #5 on: July 28, 2023, 09:43:32 am »
It’s a shelf filter, a frequency dependent potential divider.
Content much below 9Hz doesn’t get divided, whereas above 9Hz it gets reduced, 390/(220+390) = 0.64 = -3.9dB.
« Reply #6 on: July 28, 2023, 09:44:28 am »
Maybe a good addition to a weak tremolo circuit.   :icon_biggrin:
« Reply #7 on: July 28, 2023, 11:42:31 am »
How? 4dB re: what?? The signal never gets out at all.
« Reply #8 on: July 28, 2023, 11:54:44 am »
But by the same token, the signal never gets in either.
And the valve has no grid leak path shown, so the stage couldn’t operate.
We do our best with the info snippets that slip past the gatekeeper of the opening post  :dontknow:
Which in this case mentions a mute switch. So I assumed that the output was taken from the contacts of the only switch shown  :think1:
The 4dB boost was with respect to the level of audio signal.
« Last Edit: July 28, 2023, 11:58:15 am by pdf64 »
Offline joesatch
« Reply #9 on: July 28, 2023, 12:31:55 pm »
well that was the last stage and output of the clean channel .sounds pretty fantastic. i'm incorporating this 10ohm isolated ground on everything going forward
« Reply #10 on: July 28, 2023, 12:55:19 pm »
most everything I worked on where digital and analog lived on the same board/environment used a ground lift/isolation for the Digital side, but i'm confused how you got here from the shelf filter?
Offline joesatch
« Reply #11 on: July 28, 2023, 01:19:29 pm »
if you look close i have a floating chassis inside the chassis. plastic standoffs. no part of the preamp circuit is touching the outer chassis. silent as a mouse. power section (rectifier, PS) is grounded to the outer chassis via Hum-loop block. All preamp grounds measure 10 ohms resistance to outer chassis
« Last Edit: July 28, 2023, 01:24:28 pm by joesatch »
« Reply #12 on: July 28, 2023, 03:47:33 pm »
oh I found the resistor ok, have much experience with the benefits, just trying to figure out how the snippet from the pre lead to the 10 ohm R.  That's the kind of "thought process" I have, and there are few people that i've met that use that process  :laugh:
