September 25, 2026, 09:15:45 pm
Hoffman Amps Forum image Author Topic: Big problem with deluxe reverb 65  (Read 7436 times)
Offline Travis8
« on: August 02, 2023, 12:30:34 pm »
Hi,
I´m trying to fix a deluxe reverb, the issue is that turn up the reverb make a lot of hiss, the hiss only come down when I disconnect the reverb tank..
some ideas?
Offline Travis8
Re: Big problem with deluxe reverb 65
« Reply #1 on: August 02, 2023, 12:39:12 pm »
Is the TAD 4AB3C1B new one..
Offline Travis8
« Reply #2 on: August 02, 2023, 12:53:49 pm »
Also If I remove V4 noise dissapear and If I remove v3 noise still there.
Offline Travis8
« Reply #3 on: August 02, 2023, 12:57:42 pm »
I try with a new V4 and the noise continue.
the noise here: https://drive.google.com/file/d/1Tyx-001ATqgZxwEcXtoSo04p8hshFqnC/view?usp=drive_link
« Last Edit: August 02, 2023, 12:59:58 pm by Travis8 »
« Reply #4 on: August 02, 2023, 01:04:24 pm »
Offline Travis8
« Reply #5 on: August 02, 2023, 01:06:30 pm »
Offline Travis8
« Reply #6 on: August 02, 2023, 01:17:13 pm »
could be RCA cables?
The tank is very new, I think is correct.
« Reply #7 on: August 02, 2023, 01:30:16 pm »
Why was the tank replaced?
Offline Travis8
« Reply #8 on: August 02, 2023, 01:33:06 pm »
Becouse old one doesnt sound and the tremolo doesnt sound too.
Now works but with this noise
« Reply #9 on: August 02, 2023, 01:36:25 pm »
Try another cable set. OK to borrow from your sound system.
BTW, tremolo issue is likely not related to reverb issue.
Offline Travis8
« Reply #10 on: August 02, 2023, 01:38:28 pm »
Ok, i will try another cables..
Yes, I know tremolo must be another think but I didnt found it yet... tubes are new
Offline Dave
« Reply #11 on: August 02, 2023, 01:42:33 pm »
Also try a snubber cap on the return from the reverb tank like Fender used in the 70's. That's what that cap was there for.
Dave
Offline Travis8
« Reply #12 on: August 02, 2023, 01:47:16 pm »
Ok, tremolo was bad footswitch now is working
Offline Travis8
« Reply #13 on: August 02, 2023, 01:48:09 pm »
Dave
ok, never see it. I will investigate
« Reply #14 on: August 02, 2023, 02:01:41 pm »
2000pF is the same as .002µF. If cables and/or this cap don't fix this issue you need another tank. It seems like I see lots of issues with new tanks these days.
Offline Travis8
« Reply #15 on: August 03, 2023, 04:14:33 am »
Ok, I order one good RCA shielded cable to try it, the two 12AT7 are this one "TAD ECC81/12AT7-Cz" could be problematic this tube for reverb?
Offline Latole
« Reply #16 on: August 03, 2023, 06:19:56 am »
First of all, can you confirm that this amp has already worked perfectly? No hiss?
Secondly, has this amp ever been repaired by another person ?
And finally, show us a good photo of the circuit. I suspect somes wires are misplaced.
