August 05, 2026, 01:52:18 pm
Hoffman Amps Forum image Author Topic: 2553 PT position  (Read 5378 times)
Offline Leevi
    • Rikstone
2553 PT position
« on: August 09, 2023, 11:11:25 pm »
A Marshall 2553 is causing hum even if you remove the power tubes.It looks like the PT is not in an optimal position which probably causes the hum.Everything looks very original in the chassis and the both transformers are produced by Drake.I found some pictures where the PT installation differs from the model where the issue is.Pls. see the pictures
/Leevi
« Last Edit: August 10, 2023, 01:11:46 pm by Leevi »
Re: 2553 PT position
« Reply #1 on: August 10, 2023, 01:06:28 am »
Ciao Risto
Seems that the difference is the fact that the PT in one version is lying down
Is the other the version with the problem ?
Offline Leevi
    • Rikstone
« Reply #2 on: August 10, 2023, 02:26:29 am »
Ciao Franco,
The problem exists in the version with lying down PT.I wonder since everything seems to be from the factory production i.e. no mods done.
/Leevi
« Reply #3 on: August 10, 2023, 06:30:17 am »
Can you find an end bell and add it to the PT so you can mount it the other way ?
Offline Leevi
    • Rikstone
« Reply #4 on: August 10, 2023, 06:38:59 am »
I can mount it vertically without end bell.The connectors will stay unprotected but it does not matter since the cabinet is protected anyway.
/Leevi
« Reply #5 on: August 10, 2023, 10:17:15 am »
I was thinking to add the bell because it is a shield to the EMF
An alternative you can try is to dismount the PT, close the squared hole with an iron sheet
put the necessary holes for the wires and mounting bolts on this sheet, then mount the PT lying Down but on the Upper Side of the chassis
« Last Edit: August 10, 2023, 10:29:54 am by kagliostro »
Offline Leevi
    • Rikstone
« Reply #6 on: August 10, 2023, 11:01:28 am »
It's already mounted and the result is complete silence.
The bell is not an option since the connecrtors are pretty massive.Pls. see the picture.
/Leevi
« Last Edit: August 18, 2023, 09:54:30 am by Leevi »
« Reply #7 on: August 10, 2023, 02:06:37 pm »
No Humm ..... PERFECT 👍👍👍
I understand the difficulty to add one other bell
You can stop here if you want
But, if you want to cover that part of the PT an alternative can be to build an aluminium shield (1.5mm or bettter 2mm)
I'll try to draw my idea for that and I'll post it later (if the draw is good)
« Reply #8 on: August 10, 2023, 02:26:36 pm »
Here I'm (unfortunately I havent a 3D software, only 2D
This is the shield I would try in place of the missing End Bell
You must cut and drill it in a 1.5mm or 2mm aluminium sheet, then you have to bend the 3 parts at 90 degrees (when the sides are bent the shield will have the same measures of the laminations), position the shield with the missing side on the bottom and fix it to the PT bolts using treaded joint nuts and screws
Better to use 2 layers of some adhesive plastic sheet to electrically insulate the inside of the shield
« Last Edit: August 10, 2023, 02:32:20 pm by kagliostro »
