August 05, 2026, 12:13:25 am
Hoffman Amps Forum image Author Topic: Buzzing sound behind the notes  (Read 4198 times)
Offline marshallguy
  • Failure is not an option
« on: August 10, 2023, 07:30:46 pm »
Hello fellow amp enthusiast,
I found this older trend 2006 on the Amp Garage dealing with the same issue I’m having. His build was derived from a Dumble Overdraft Special. Different amp then mine but same exact problem.
Here’s his response after disappearing for almost a year and someone finally asked if he ever found and fixed the problem……
“I did get that amp to mellow out and it turned into a real sweetie. I wound up making some changes in the power supply resistor string. That tightened up the amp real nice and got rid of the ghost notes.”
Naturally he didn’t say exactly what he did in the B+ resistor string Changed some values?  Link to a Dumble OD not sure if his build was the same.
https://www.schematicheaven.net/dumbleamps/97fullschem.pdf
Can someone with some experience to this chime in? I’ve tried everything else. Maybe which resistor(s) to change in value?
The problem is narrowed down between V4b and the output jack speaker.
Thanks.
Link to some songs recorded with similar amp I built.
https://soundcloud.com/user-259182186/after-the-storm
« Last Edit: August 10, 2023, 09:34:35 pm by marshallguy »
Offline marshallguy
Re: Buzzing sound behind the notes
« Reply #1 on: August 14, 2023, 03:37:53 pm »
Thanks.
TH\his discussion is now closed. Turns out problem is with the speakers, cone cry. :sad2:
