September 19, 2026, 01:13:37 am
Hoffman Amps Forum image Author Topic: Improving a DI  (Read 14409 times)
Offline separateness
  • dallier
Improving a DI
« on: August 15, 2023, 11:25:51 pm »
Gentlemen
I have at my home one Behringer Ultra-DI 600P.  While not perhaps a most enviable piece of gear I do find use for it.  Namely I place it between my bass amplifier and its speaker cabinet, and this allows me a direct signal which I can run to my recording console. I have found it to work quite well and have had no issues with it.  Well, I thought I hadn't until I was looking at a manual for the thing online and learned that frequency response was from 40hz at which point it was already down -3dB. As some one who tunes by bass BEAD, I was appalled. Having pored over numerous options of building something new or buying something better, I am now considering merely modifying what I already have.  Attached is a schematic I drew up of the thing, or at least as best a schematic as I could cobble together without the thing in front of me (for, scoundrel that I am, I am writing this while at work).  You will note that it has a ground lift for the XLR, a sort of high pass filter and a pad.  It seems like the HPF should not work when the pad is not used but I could be misinterpreting the schematic.
Anyway, my plan of attack is to lower each of the resistor values by a decade which I think will improve the low frequency response of the transformer.*  Am I misinterpreting facts, science and reality in supposing this should work?  I know I will thereby reduce the power handling capability of the device but it is suppose to work with amps up to 3kW.  My bass amp is 100W.
*This is based on information gleaned from an ancient groupdiy post by the illustrious PRR.
