September 20, 2026, 12:06:34 pm
Hoffman Amps Forum image Author Topic: Which resistor would you keep?  (Read 4965 times)
Offline pbman1953
« on: August 25, 2023, 05:45:39 pm »
I'm thinking of replacing some older parts in an Acoustic 370 amp (1971)amp. Never worked on
I have 4 carbon comp's in the whole amp-
The 22 ohm 2 w measures- 23.8
The 10 Ohm 2w measures- 10.9
The 56k measures - 59.7
The 270k measures 297k. I have new 270's that measure out of the package at 243k
Would keep the ones that are close to the original or replace them due to age.
« Last Edit: August 25, 2023, 05:55:51 pm by pbman1953 »
Offline Dave
Re: Which resistor would you keep?
« Reply #1 on: August 25, 2023, 05:57:49 pm »
If the amp sounds good and doesn't exhibit any problems, I wouldn't touch a thing.
Dave
Offline pbman1953
« Reply #2 on: August 25, 2023, 06:14:34 pm »
Thanks Dave!
I'll leave those as is but there are small electrolytics that are bulging on the end's. I'll probably update them
Offline pbman1953
« Reply #3 on: August 27, 2023, 10:31:21 am »
Ok, so I left the resistors because they were still in spec but I figured to replace the caps just because they're old. I installed all new caps and the amp came up fine but seem to lose volume after a minute. Meanwhile while the old parts were out I tested them again an they seamed to be ok. Feeling something was wrong with the new parts I put the old ones back and the same thing happened.
Thanks for any help
« Reply #4 on: August 27, 2023, 06:39:26 pm »
... I installed all new caps and the amp came up fine but seem to lose volume after a minute. ... Feeling something was wrong with the new parts ...
"Lose volume" sounds like a loose connection somewhere.
I first thought that maybe you had a poor connection with one of the new car, until you said you had the same symptom after putting the old parts back in.  So unless you made some not-great wiring both times, look to loose jack or socket contacts, or a broken resistor.
Offline pbman1953
« Reply #5 on: August 28, 2023, 07:36:57 am »
I found it with a chop stick. One cap i didn't change had a bad connection. It's leg was iffy.
I'll get a new one.
Thanks!
