September 19, 2026, 10:31:53 pm
Hoffman Amps Forum image Author Topic: Changing value of potentiometer  (Read 10082 times)
Offline Mypalmurph
  • Bums hate bums the most
« on: September 08, 2023, 01:57:43 pm »
What draw backs are there to changing the value of a potentiometer by placing a resistor between the track ends? for instance - 33k resistor end to end across a 250k pot to mark it roughly 30k
Sean Gannon
Re: Changing value of potentiometer
« Reply #1 on: September 08, 2023, 03:18:05 pm »
Solder tack the pot and resistor, connect multimeters between each set of luggs, turn the dial and measure the way R changes between input/wiper/output. Then you’ll figure out if the trick works for what you need. Hard to guess what the pros and cons are if you don’t tell anyone why you’re thinking of doing this.
Offline Mypalmurph
« Reply #2 on: September 09, 2023, 12:29:18 am »
Well I want to use a 25k pot for my mids on the Hoffman 6v6 plexi build I’ve got on my bench and I only have a 250K pot.  I would normally order what I need but I already did and the the post office has misplaced the package so any who.  I feel like maybe it’d work fine on a dimmer but maybe not the amp- I have time to work on my amp now my wife is busy and I can get into building uninterrupted- I don’t wanna swap the pot out if the resistor doesn’t work right- but…..
Sean Gannon
« Reply #3 on: September 09, 2023, 03:40:12 am »
I don’t think that will work out well as a mid control, sorry.
Offline dwinstonwood
« Reply #4 on: September 09, 2023, 06:20:02 am »
Mypalmurph, this Tone Stack Calculator might help to give you a visual idea of the frequency curves using different pots, etc.
https://www.guitarscience.net/tsc/marshall.htm#RIN=1300&R1=33k&RT=220k&RB=1M&RM=25k&RL=517k&C1=470p&C2=22n&C3=22n&RB_pot=LogB&RM_pot=Linear&RT_pot=Linear
The link goes to a Marshall tone stack (others along the top). First, click "Take Snapshot." Then, click "Edit," change RM to whatever value you want, and click "Apply." You will then see the two curves side by side.
Offline Dave
« Reply #5 on: September 09, 2023, 07:27:46 am »
The mid pot only uses two lugs of the pot as a variable resistor. It will work fine as a mid control. Personally, I would tie the resistor to the two lugs you will be using since it is being used as a variable resistor anyway. Another thing, you are not limited to 25k or thereabouts. You could play with the resistor value until you get the mid sweep that you like. You might even like 250k in that position, wouldn't hurt a thing, it would just give you tons of mid sweep all the way down to zero.
Dave
Offline bmccowan
  • Better builder than player
« Reply #6 on: September 09, 2023, 08:04:33 am »
Dave
I would leave out the pot for now and install a 10K fixed resistor in its place. Order the pot you need and quickly install it when your wife is not looking.
Mac
John Prine
« Reply #7 on: September 09, 2023, 10:53:05 am »
Not so. This amp uses all three lugs just like most all old Marshalls.
Offline Dave
« Reply #8 on: September 09, 2023, 11:04:23 am »
So it does... I stand corrected.
Dave
« Reply #9 on: September 09, 2023, 12:43:08 pm »
But with the arrangement described in post 1, the actual response will be somewhat different to what the calculator shows.
eg consider that with the mid pot set electrically halfway, the resistance between the pot wiper and circuit common (and hence mid cap/RC filter frequency) will be over 60k, rather than about 12k.
« Reply #10 on: September 09, 2023, 02:22:39 pm »
All your medium to low values will be bunched-up in the last 1/10th of a turn.
Bright-Bright-Bright-Bright-Bright-DULL.
Why would pot makers make many-many values if it was just that easy?
Offline dude
« Reply #11 on: September 11, 2023, 03:14:19 pm »
Could the resistor trick be used to make a dual pot’s both sides be equal as usually they are not. Say, for the master dual pot in a LaMar type MV?
« Reply #12 on: September 12, 2023, 06:06:18 am »
I suppose so. But if achieving perfect symmetry is that important, a Dumble style balance trimmer is typically used.
Note that as soon as such a master volume is turned down from max, that symmetry / balance seems likely to be lost. As pot taper conformance to the nominal isn’t specified, could be anything.
Offline dude
« Reply #13 on: September 12, 2023, 10:15:49 am »
I used a R to balance the dual MV's pots in a 6V6 Plexi.  The balance (after using a R on one side) was perfect on both sides with pot on the table, seems to work well in the amp but I didn't check the balance in the amp when on and playing, I will do that when I open the amp soon and report.  Thanks for the tip on the Dumble balance trimmer.
« Reply #14 on: September 15, 2023, 06:19:09 pm »
....  a Dumble style balance trimmer is typically used. ....
May be here is late ..... but, what do you mean with Dumble style balance trimmer ???
« Reply #15 on: September 16, 2023, 07:50:37 am »
See https://el34world.com/charts/Schematics/files/Dumble/Output.pdf
Offline bmccowan
« Reply #17 on: September 16, 2023, 10:18:06 am »
Oh... you mean "Williamson-style balance trimmer" (see R12).   :laugh:
It's remarkable how much goes back to Williamson. I've been contemplating building an amp similar to the Gibson GA-50 and wondering about the two chokes - and here they are in that schematic - almost identical spec.
Mac
John Prine
Offline shaun
« Reply #18 on: September 16, 2023, 01:40:10 pm »
 :l2:
That gave me a good laugh precisely because I wondered that same thing once or twice years ago. But you'll probably get a shift in the way the pot works which probably won't feel natural to the end user. Plus, we're talking about signal path, so your signal would be effected by the dynamic between the pot and the added res. This may or may not be subtle, but in chasing tone, there is no single magic bullet; a great amp sounds great because of a hundred little tweaks and adjustments in the right direction. In my thinking, your short cut would probably be the opposite of that.
With gratitude.
« Reply #19 on: September 16, 2023, 02:10:54 pm »
Thanks Pdf64
That was remembering something to me ....
Exactly
Thanks HBP
Offline passaloutre
« Reply #20 on: September 16, 2023, 10:55:33 pm »
Don’t some people use a 250k in the Mid pot to act as a raw control?
« Reply #21 on: September 17, 2023, 12:15:19 am »
Yes, in a Fender style TS. But can't do that in a Marshall TS.
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« Reply #22 on: September 18, 2023, 02:55:27 am »
Have you tried bypassing the tonestack ?
The frequency curve is way more rich than wirh a tone stack, even with all the controls set at 10.
From  the other side, you  loose the adjustment capabilities.
If this particular build is for you, give it a try:
hook up a switch to the gnd side of the tone stack to activate/desactivate it.
My last build is a Fender Showman (normal channel only, no tone stack,  PS  caps beefed up, 2X El34 ). The tone of this amp is incredible.
But, if you're not used to control your tone with your guitar, it is not the most versatile amplifier, but certainly one of the.most.best sounding.
P.S.: call me Alvin.
