September 08, 2026, 12:17:57 pm
Hoffman Amps Forum image Author Topic: Supro Super 1606 / Gretsch 6150 layout  (Read 35230 times)
Offline blackcorvo
« on: September 14, 2023, 01:28:32 pm »
I've been working on an amp inspired by the Supro 1606 /  (but using two PCL82 tubes), and recently I haven't had the space to keep working on it at home. However, I had some free time at work, so I drew up the original amp's layout on DIY Layout Creator to pass the time, and because there's no drawn version of it anywhere.
I've also compiled all the reference pictures I've found into a Google Drive folder for anyone to view, as wellas the DIYLC file:
https://drive.google.com/drive/folders/1TgIn41hioDNH7-CvfoIGfYPfNP6IvQ3O
You may notice there's 2 variants of this amp: one sporting an indicator light and panel mounted fuse holder, and one without the indicator and with an internal fuse holder.
I chose to base the layout on the latter, as I feel it covers the more relevant parts of the amp.
Of course, there are modern improvements we can do to make the amp as noise-free and reliable as possible, like a grounded power cable, twisting the AC lines, and using resistors to make a center-tap on the 6v AC wiring, but I think having a representation of the original amp online is a valuable tool to have.
[EDIT] fixed missing P.T. ground wire.
« Last Edit: September 14, 2023, 06:09:30 pm by blackcorvo »
She/Her since August 2021
Re: Supro Super 1606 / Gretsch 6150 layout
« Reply #1 on: September 14, 2023, 03:23:10 pm »
You're missing a very important wire for the power transformer. There should be a red/yellow wire that connects to chassis. Some of your pics show this wire connected to a ground lug on the 6V6 socket. Your schematic does not show this wire connected to ground either. This is not an optional wire. It must be connected to ground.
« Last Edit: September 14, 2023, 03:34:50 pm by sluckey »
Offline blackcorvo
« Reply #2 on: September 14, 2023, 05:37:09 pm »
Thank you very much! I'll rectify that error right away.
Offline blackcorvo
« Reply #3 on: September 15, 2023, 10:43:37 am »
And here's what I am calling my "modernized" take on the amp, with some changes to bring it up to modern safety standards and building practicies (twisting AC lines to reduce hum, adding resistors to the 6v line to give it a "center tap", grounded power wire, shielded cables on all signal wires, etc), while keeping the majority of the layout very similar.
I also added Jeff Bober's mod, but it's totally optional.
[EDIT] Fixed misplaced resistor lead.
« Last Edit: September 15, 2023, 02:13:17 pm by blackcorvo »
« Reply #4 on: September 15, 2023, 01:31:45 pm »
V1 pin 2 no longer has a resistor to ground.
Offline blackcorvo
« Reply #5 on: September 15, 2023, 02:04:47 pm »
Thank you. THIS is why I post here, I sometimes don't catch obvious errors like that. Corrected.
Offline DannyNYC
« Reply #6 on: December 21, 2024, 01:36:00 pm »
I wanted to build a 1606 Supro Super, but with an eyelet board like fender instead of point to point component to component. Has anyone on here transcribed a super diagram to an eyelet diagram?
Offline SEL49
« Reply #7 on: December 21, 2024, 03:48:54 pm »
The 1606 is the same as the 6606 except the 1606 has no tone control. Here's a 6606 layout.
Offline blackcorvo
« Reply #8 on: February 20, 2025, 09:57:54 am »
Thank you! I hadn't seen it till now so I i ended up prototyping my own layout for now.
I know that it's been a while, but I've decided to get back on this project. I've wanted to try making an eylet board build for ages, and this is the result so far:
i=fRfKigcDlnzyoaPe
If I do use an eyelet board in the final build, I'll definitely try something more substantial than a random cut off a cardboard box hahaha!
I'm now just struggling with the balance between B+ (currently 147.5v) and output stage operating point. I want to get as close as possible to the 6W output the original 1606 amp could provide, but it seems it'd require more B+ voltage (170v), but then if I make a voltage tripler to get it, the B+ goes over 200v without load, which is above what my quad-capacitor can handle, and I'd like to keep it in the project because it looks cool, and allows me to make my eyelet board smaller.
That's about it, see you on the next update.
Offline blackcorvo
« Reply #9 on: March 16, 2025, 06:31:43 pm »
Last update on the schematic. Did some changes for better response (IMO) to suit the PCL82's triodes.
Also used a 32v+32v P.T. to actually get around 150V B+.
Sound sample:
