September 16, 2026, 12:44:16 am
Hoffman Amps Forum image Author Topic: 5B6 build... no output  (Read 18261 times)
Offline zephyrblau
« on: September 17, 2023, 03:33:21 pm »
the transformer was harvested from a Wurlitzer model 6144 (320 - 0 - 320) neither the layout nor schematic indicate output voltages of the OEM PT.
the board is a Hoffman 5F6 type modified as required. I've moved the 25R and 6K8 to the board. (next page) I'm working from the layout and don't know if there are any mismatch(s) between this and the schem.
after completion I put the unit on a Variac as a test to see if any of the smoke wanted to escape. so far so good ?
the voltage readings are not as expected. (next page)
I'm a paint by numbers guy who knows how to solder but little else.
Offline zephyrblau
Re: 5B6 build... no output
« Reply #1 on: September 17, 2023, 03:38:19 pm »
more pix.
« Last Edit: September 17, 2023, 03:41:47 pm by zephyrblau »
Offline zephyrblau
« Reply #2 on: September 17, 2023, 03:50:12 pm »
voltages:
filters L to R;
layout says 400. I have 412
layout        320            411
                 300            383
« Reply #3 on: September 17, 2023, 03:55:46 pm »
Is your speaker jack a Switchcraft 12A? If so, I believe the yellow wire is connected to the switch terminal. It should be connected to the tip terminal.
Offline zephyrblau
« Reply #4 on: September 17, 2023, 03:59:35 pm »
here's where things really start to get wacky;
circled points L to R;
layout says 160. I have 370
layout         2.6             5.4
2.6              5.4
Offline zephyrblau
« Reply #5 on: September 17, 2023, 04:02:29 pm »
it is. I'll double check. would that cause the wonky voltages I'm seeing ?
« Reply #6 on: September 17, 2023, 04:07:36 pm »
No, but it will certainly cause you to have no output.
« Reply #7 on: September 17, 2023, 04:33:34 pm »
layout        320            411
                 300            383
Small tubes are not sucking current. Are they wired right? Heaters too? Are they in their sockets?
-OR- your "10K" are really 1k.
Offline AlNewman
« Reply #8 on: September 17, 2023, 04:35:00 pm »
What are your voltages at all socket pins?  Including AC/heater voltages?
Offline zephyrblau
« Reply #9 on: September 17, 2023, 04:35:21 pm »
output jack wiring corrected. thanks!
gosh my dummy load is warming up  :worthy1:
Offline zephyrblau
« Reply #10 on: September 17, 2023, 05:04:54 pm »
layout        320            411
                 300            383
yes... and no.
while I routinely check the comps to make sure they're in spec. I may have skipped that here. I may have taken it on faith when I ordered 10K that all were the correct value. the value striping on this modern stuff is pretty crappy. so... one is 10K the other is 1K.
back in a moment.
Offline AlNewman
« Reply #11 on: September 17, 2023, 05:17:39 pm »
It looks like on your pictures you have 2 heater wires running from tube to tube.  If you're following the layout, there should only be one with a chassis return.
Offline zephyrblau
« Reply #12 on: September 17, 2023, 05:24:18 pm »
proper 10K installed. PS outputs are now in spec.
« Reply #13 on: September 17, 2023, 05:26:41 pm »
That dummy load should not be warming up unless you have a signal (guitar, signal generator, etc.) connected to the input. If it is getting warm that means you have an oscillation going on. Better plug in a speaker to know for sure. An oscillation would most likely be caused by incorrect phase of the negative feedback. This can cause damage to the output transformer.
Offline zephyrblau
« Reply #14 on: September 17, 2023, 05:29:38 pm »
new readings for these points are as follows;
layout says 160. I have 290
layout         2.6             4.7
                  2.6             4.1
Offline zephyrblau
« Reply #15 on: September 17, 2023, 05:39:10 pm »
got it.
@ this point I there's some family chores I can't put off (any longer than I already have). I'll be back ASAP. again, my thanks to all.
Offline zephyrblau
« Reply #16 on: September 19, 2023, 07:51:32 pm »
yep... "hash" of some sort. definitely not 60 cycle hum. I need to double check the relocation of these two.
« Reply #17 on: September 19, 2023, 08:03:13 pm »
Disconnect the 6.8K from the speaker jack. Any better?
Offline zephyrblau
« Reply #18 on: September 19, 2023, 08:13:41 pm »
agreed.
...and originally I had the green 6.3V wire going to the ground side of the pilot light and the green-yellow wire going to the tip. I've since reversed this.
my thinking is that this is AC and polarity is not an issue. too simplistic ?
I also have short jumpers from each filament to ground for all sockets.   :w2:
Offline zephyrblau
« Reply #19 on: September 19, 2023, 08:24:07 pm »
no change.
Offline AlNewman
« Reply #20 on: September 19, 2023, 08:53:03 pm »
agreed.
Sounds like you got er all figured out.
Offline zephyrblau
« Reply #21 on: September 20, 2023, 04:04:25 pm »
agreed.
only the filament wiring unfortunately.
Offline zephyrblau
Re: 5B6 build... no output / the plot thickens...
« Reply #22 on: September 20, 2023, 04:06:29 pm »
it seems that someone who shall remain nameless got his hands crossed and installed a 6SL7 in V1 (S/B 6SC7)
Offline zephyrblau
« Reply #23 on: September 21, 2023, 01:47:47 pm »
the net result of the above is no change in the "hash" output.
I've checked the resistance of the primary side of the O/T and both sides measure 61R (+ / - .5ohm)
@ the moment I'm building a proper cap discharge "pen".
« Reply #24 on: September 21, 2023, 03:01:01 pm »
Divide and conquer. Pull the 6SL7. Any better?
Offline zephyrblau
« Reply #25 on: September 21, 2023, 03:47:29 pm »
better but, not good.
Offline zephyrblau
« Reply #26 on: September 21, 2023, 04:00:54 pm »
...and I should clarify something. the "hash" that I refer to above is indeed an oscillation. the owner supplied a few 6SL7s, all Ruskie. one of which, the first one I tried is especially noisy with some crackling added for good measure.
the other two don't have the crackle but the oscillation persists.
« Reply #27 on: September 21, 2023, 05:04:04 pm »
Not much left... power tubes and power supply. Wiring error should be high on the list.
Offline zephyrblau
Re: 5B6 build... yep... they don't call me bonehead for nothin'
« Reply #28 on: October 04, 2023, 10:47:33 pm »
it seems that someone forgot a ground connection.
« Reply #29 on: October 05, 2023, 06:15:58 am »
Is everything working now?
Offline zephyrblau
« Reply #30 on: October 05, 2023, 10:49:51 pm »
not yet. better but not OK. I'll post updated info tomorrow (Fri.)
« Reply #31 on: October 06, 2023, 12:32:49 am »
Time for another set of voltages?
Offline zephyrblau
« Reply #32 on: October 06, 2023, 07:22:29 pm »
yep!
per the attached layout I put the Fender values are listed first. mine are in brackets. numbered 1 through 9 from left to right. yellow was probably a better color to use, but...
1) 400 [490]
2) 320 [461]
3) 300 [433]
4) 160 [417]
5) 180 [140] note; this drops to 47 if I unplug the umbilical cord / control panel. adjusting the Vol or Tone settings has no bearing.
6) 390 [490]
7) 180 [135]
8) 320 [461]
9) 390 [490]
Offline Esquirefreak
« Reply #33 on: October 07, 2023, 11:50:50 am »
Cathode voltage on the power tubes would be good to know. Unusually high voltages usually indicate that something is not pulling its share of current.
/Max
Offline zephyrblau
« Reply #34 on: October 07, 2023, 12:24:08 pm »
does 63V sound right ?
« Reply #35 on: October 07, 2023, 12:27:34 pm »
No, but it depends on what value the resistor is. Compare it to the schematic or layout.
Divide that voltage with the resistance of the cathode resistor to figure out how many milliamps the power tube are pulling.
/Max
Offline zephyrblau
« Reply #36 on: October 07, 2023, 01:45:14 pm »
250 ohms ... pretty standard Fender stuff of the era (?)  25 ma ?
« Last Edit: October 07, 2023, 01:48:54 pm by zephyrblau »
« Reply #37 on: October 07, 2023, 03:38:20 pm »
250 mA?
« Reply #38 on: October 07, 2023, 04:43:19 pm »
63vdc/250 ohms = 144mA
if it's shared then 144/2 mA
Offline AlNewman
« Reply #39 on: October 07, 2023, 07:20:46 pm »
Have you actually tested the resistance on your 250R resistor?  Because with your described voltages, it's putting out like 15W of heat, which is fairly significant.  That, and your power tubes are running at 200% +
« Reply #40 on: October 07, 2023, 07:52:59 pm »
63 ÷ 250 = .252A on my calculator. Have I misunderstood something here?
Sorry.
/Max
« Reply #41 on: October 08, 2023, 10:14:39 am »
Measure the 250 ohm resistor with your R-meter to get its actual resistance.
Offline zephyrblau
« Reply #42 on: October 08, 2023, 11:03:57 am »
somewhere along the line it's burned up. I didn't verify it prior to installing but I do recall it being hot at some point during testing... too hot to touch if that's relevant.
it was purchased as part of a pair and the other reads 247 ohms. I'll be swapping the other one in shortly.
« Reply #43 on: October 08, 2023, 11:19:49 am »
 :laugh:  dyslexia  I keyed in 36/250 TWICE
sorry for the confusion
« Reply #44 on: October 08, 2023, 12:01:17 pm »
Haha, that happens to me every now and then too  :laugh:
Hopefully voltages will come down when the bias is steady.
However, I'm at a loss with the test point where you noted the voltage dropping.
/Max
« Reply #45 on: October 08, 2023, 05:26:53 pm »
appears to be the PI input, whichever plate pin 5 is
EDIT:  looks like you remove G1's reference to ground through the Vol pot, sending into lala land??
« Last Edit: October 08, 2023, 05:30:01 pm by shooter »
Offline zephyrblau
« Reply #46 on: October 08, 2023, 06:06:25 pm »
per entry #5 above where I note the voltage drop this is the only change of all listed when I pull the umbilical. all other testing is done with the control panel hooked up.
dropping resister changed out.
control panel and layout pix attached.
« Reply #47 on: October 08, 2023, 07:09:46 pm »
Input jacks are wired wrong.
Offline zephyrblau
« Reply #48 on: October 08, 2023, 08:54:20 pm »
better ?
« Reply #49 on: October 08, 2023, 08:58:16 pm »
They are on the correct lug now but the soldering job looks terrible.
