September 15, 2026, 11:04:39 am
Hoffman Amps Forum image Author Topic: JTM45 One wire mod  (Read 4506 times)
Offline isaac_teller
JTM45 One wire mod
« on: October 20, 2023, 07:45:24 am »
Hello. Please correct me if I am wrong. I am building a JTM45 and I want both options-standard JTM45 and cascaded input stages. From Robrobinettes site it looks like I could make it work just by adding a SPST(on-on) switch with one side going to the bright input and the other side going to the wiper of the normal volume. Is it that easy? Seems like I might be missing something. Thank you.
https://robrobinette.com/images/Guitar/Bassman/5F6A_One_Wire_Cascade_Mod_Schematic.gif
Re: JTM45 One wire mod
« Reply #1 on: October 20, 2023, 08:27:45 am »
It’s a bad idea to cascade common cathode gain stages that share cathode biasing components.
It works fine when the cathode bypass cap is new, but as it ages, a positive feedback loop develops, which will eventually cause oscillation.
Hence it’s a good idea to split the cathodes if you’re going to do this.
