September 15, 2026, 08:53:57 am
Hoffman Amps Forum image Author Topic: Impedance/build question  (Read 4235 times)
Offline Diverted
« on: October 25, 2023, 10:08:22 am »
Hi all, quick question:
If I have an output transformer rated at 6.6K center tapped w/4, 8 and 16 ohm secondaries, designed for 6V6s and using the 8 ohm winding into an 8 ohm speaker ...
If I were to swap the 6V6s for 6L6s and rebias, would I use the 4 or 16 ohm winding for them? I always get confused on which way to go.
Reason I'm asking: I want to build a marginally higher power Princeton Reverb-ish circuit. I am using a power transformer rated at 300-0-300@173ma, and a 30w 6.6K output transformer. I plan to do the Stokes mod (higher B+ to phase inverter), add in a mid pot and that's about all I would change except for some unrelated changes, like a slower tremolo speed etc. I'm hoping for up to 15W w/6V6s and maybe 22-25 or so with 6L6s and a re-bias.
Thanks.
Re: Impedance/build question
« Reply #1 on: October 25, 2023, 10:33:24 am »
6L6s, switch 8R speaker to the 16R tap (reflecting 3k3 Pr Z)
Or, break it down
6k6:16 = 412.5:1 Z, 412.5 x 8 = 3k3
6k6:8 = 825:1 Z = etc
6k6:4 = 1650:1 Z = etc
« Last Edit: October 25, 2023, 10:43:18 am by tubeswell »
Offline Greenwichpaul
  • I love valve amps
« Reply #2 on: October 25, 2023, 10:45:25 am »
Edit: we are now in alignment. 8 ohm speaker on 16 ohm tap would reflect 3.3k to the OT primary
« Reply #3 on: October 25, 2023, 10:46:28 am »
4am math
Offline Diverted
« Reply #4 on: October 25, 2023, 12:38:11 pm »
Thanks for the explanation! I will not have to ask this again! I understand the math, much appreciated.
