September 15, 2026, 05:48:28 pm
Hoffman Amps Forum image Author Topic: In which way the capacitor modify the things in this Speaker arrangement ?  (Read 4660 times)
In simple HiFi (or music reproduction) Speaker cabinets often there is a pair of Speaker one for Lower frequencies and other for Higher frequencies
The most simple arrangement don't use a real Crossover unit with inductors and capacitors, only one capacitor is series with the High frequency speaker is used
What I don't know is ... in this simple arrangement which is the resulting impedance of the combined Speakers ?
If I put two 8 ohm speakers in parallel I know I obtain a virtual 4 ohm speaker
But when there is a capacitor that cut frequencies like in the schematic, what happen to the resulting impedance of the coupled speakers ?
Many Thanks
« Last Edit: October 30, 2023, 04:51:50 pm by kagliostro »
the simple answer is "it's still 4 ohms"  otherwise you have to do speaker math over frequency range, plotting on log paper with slide rules n such  :icon_biggrin:
The cap is there to keep low frequencies from reaching the tweeter ( or high frequench driver if you want to call it that ) and damaging it - of course you probably know that already
Shooter has it right I believe.
« Last Edit: October 30, 2023, 08:36:50 pm by mresistor »
All voice-coil speakers have rising impedance above midrange.
These one-cap "crossovers" usually start past the woofer's midrange, where its impedance is near double or more.
Also you don't put a lot of power above ~~1KHz so the amplifier won't strain into a "wrong" impedance.
So yeah, what Shooter said.
Many thanks friends
