September 16, 2026, 06:37:04 pm
Hoffman Amps Forum image Author Topic: Mixing parallel triodes  (Read 6885 times)
Offline clyde
« on: November 10, 2023, 11:18:16 am »
I will be using a 12AX7 with dissimilar cathode circuits and dissimilar coupling caps for each triode, a separate 100k plate resistor for each and will combine the outputs.  Are series (mixing) resistors needed after the coupling caps?  One triode will be switched out to be used in a cascaded stage which is why I need dissimilar circuits.  Thank you.
Re: Mixing parallel triodes
« Reply #1 on: November 10, 2023, 11:36:53 am »
In the VOX AC30CC2 they do it this way, joined inputs (and have joined cathodes) but I think you can go also with separated cathodes
Offline clyde
« Reply #2 on: November 10, 2023, 12:37:15 pm »
Thank you, not quite, I'll only have one volume for the combined outputs. There won't be a "normal" channel.
« Last Edit: November 10, 2023, 12:42:57 pm by clyde »
« Reply #3 on: November 10, 2023, 01:03:40 pm »
Probably a good idea to use mixing resistors. Might make more sense if we could see an actual schematic.
Offline clyde
« Reply #4 on: November 10, 2023, 03:05:50 pm »
« Last Edit: November 10, 2023, 06:09:02 pm by clyde »
« Reply #5 on: November 10, 2023, 03:18:05 pm »
Ciao Clyde
Revise your schematic, seems that as is it won't work
Offline stratomaster
  • Don't guess, measure.
« Reply #6 on: November 10, 2023, 03:45:37 pm »
This will block DC from reaching the anode.
Offline clyde
« Reply #7 on: November 10, 2023, 06:08:02 pm »
Sorry, I was in a rush to get out the door at the moment.  Let's try this:
« Reply #8 on: November 10, 2023, 07:50:20 pm »
