September 17, 2026, 10:54:58 am
Hoffman Amps Forum image Author Topic: OT matching crisis.  (Read 7612 times)
Offline joesatch
  • save me from myself.
OT matching crisis.
« on: November 16, 2023, 08:08:17 am »
gonna start my jtm45/35 style build. everyone under the sun is telling me this is the wrong OT to use with EL34 (using because i have them)  and i can only really use 6V6 or EL84's with it. Now this set was initially designed for a TW Express which uses EL34. Running the math,  (plate voltage squared)divided by output tubes wattage). Ex,  (400 x 400)/(25 +25) and this comes to 3200. This OT is 6.6k so the math says no but this OT was designed for an amp which uses EL34 (germino uses this exact OT in his Lead 35 which can use any power tubes so he says).  I will be using a GZ34 rectifier. What power tubes can i use and what should grid leak resistors be, screen resistors, grid stoppers be??  i have no issues getting the right output tubes (5881, kt66, etc.)
Re: OT matching crisis.
« Reply #1 on: November 16, 2023, 08:15:38 am »
put your 8 ohm speaker on the 16 ohm tap, walla 3.3K
Offline joesatch
« Reply #2 on: November 16, 2023, 08:21:11 am »
my cabs are 16 ohms
« Reply #3 on: November 16, 2023, 08:42:14 am »
Not a crisis. Something you should commit to memory... AN OT HAS NO IMPEDANCE. IT HAS AN IMPEDANCE RATIO. Write "impedance ratio" 100 times.
So, having learned that, you can now realize that your OT impedance ratio is 6.6K:4/8/16Ω could just as easily be labeled 3.3K:2/4/8Ω. Ratio is still the same. Just as 1:5 is same as 2:10 is same as 4:20. Makes sense, right?
P/P 6V6s are often operated at 6.6K impedance so your OT would be a good match to a 4/8/16Ω speaker load.
P/P EL34s are often operated at 3.4K impedance so that same OT would be a good match for 2/4/8Ω speaker load.
See how easy that is?
Offline joesatch
« Reply #4 on: November 16, 2023, 08:48:04 am »
ok thanks. i will likely just hardwire the 16 ohm tap to one speaker jack and use it for 8 ohm or 16 ohm cabs . i never use anything lower than 8 ohm cabs. math is hard :l2:
NFB off which tap?
« Last Edit: November 16, 2023, 09:01:48 am by joesatch »
« Reply #5 on: November 16, 2023, 11:16:05 am »
NFB off which tap
math
:icon_biggrin:
« Reply #6 on: November 16, 2023, 11:30:04 am »
  ... everyone under the sun is telling me this is the wrong OT to use with EL34 …
Depending on what the other conditions affecting the operating point are, they’re almost certainly wrong / misguided.
Clearly, a 6k6 OT doesn’t preclude the use of EL34, as the Express demonstrates. You may just need to amend the JTM45 circuit to accommodate the higher screen grid current that EL34 will draw, especially so at high loading.
Offline joesatch
« Reply #7 on: November 16, 2023, 12:21:27 pm »
i will copy the grid leaks, screen resistors and grid stoppers from the express. the express doesn't halve the speaker impedance though with this OT (16ohm goes to 16 ohm speaker, 8 ohm goes to 8 ohm speaker). PT is the same as express as well so my B+ likely to be the same. the one difference is i will be using the tube rectifier
« Last Edit: November 16, 2023, 12:26:04 pm by joesatch »
« Reply #8 on: November 16, 2023, 12:57:30 pm »
Probably best to forget about the express since you're building a different amp.
