September 18, 2026, 07:11:11 pm
Hoffman Amps Forum image Author Topic: Trainwreck Express weird note decay  (Read 6021 times)
Offline Ledvedder
« on: November 17, 2023, 11:02:32 pm »
Hi everyone, it's been a while. I finished up an Express build tonight. When testing it, I noticed this strange noise while notes are decaying. Any thoughts what to check?
https://on.soundcloud.com/WX9rH
Re: Trainwreck Express weird note decay
« Reply #1 on: November 19, 2023, 05:37:30 am »
Have you tried different tubes?  Is this a combo Trainwreck or a head?  If a combo, does it still do this when outside the cabinet?  I'd check soldering. Have you chopsticked the amp?  Have you tried a different speaker?
Do you have a passive effects loop in the mix?  Did your soundclip involve any pedals or were you plugged straight in?
Can you post hi-rez photos of the chassis interior?
You might do a search on the forum about "enhance cap" which is a smoothing cap across on of the LTPI plate resistors.
Offline Ledvedder
« Reply #2 on: November 19, 2023, 09:20:55 am »
It's a head. No effects loop. I did chopstick everything, and it all seemed fine. I realized that I had it biased pretty cold. After bumping it up to about 42ma, that noise went away.
Offline Latole
« Reply #3 on: November 19, 2023, 09:29:48 am »
42 ma at what plate volts ?
I bias close to 60% power dissipation not 70
Offline Ledvedder
« Reply #4 on: November 19, 2023, 09:36:55 am »
396v.
Offline Ledvedder
« Reply #5 on: November 19, 2023, 09:38:15 am »
The enhance cap is a 220pF cap across the 82k resistor? I'll have to give that a try.
« Reply #6 on: November 19, 2023, 10:42:07 am »
Yes, 120p-220p range across the 82k LTPI plate resistor.  Glad you got it resolved!
